3..2..1..
basically, my au3 forte
has been getting close to 500kms to a tank of petrol for the last couple of months, i dont take much notice of what i put in it, e10/95, doesnt seem to matter which, no significant difference. but the last two tanks of fuel ive struggled to get 250/300, both tanks were from seperate servos. its running as averagely has it ever has. its always had a weird miss at idle, and sometimes its a bit lazy off the mark, but its been like that since i got it so i doubt that its the cause. really the fuel economy was one of its few redeeming qualities... without that i doubt it will survive much longer. any ides on possible causes? |
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
Have you changed your normal routes?
UK
not here much anymore
all the usuals - coils, plugs, leads etc. Maybe 02 sensors. AU's are a fickle bloody thing, they seem to let go with no warning.
2024 F150 XLT
ROCKING THE EL FUTURA
clean the throttle body change plugs and leads also clean the air filter.
its letting you know everything needs a clean.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
here you go
http://www.fordforums.com.au/showpos...9&postcount=43 http://www.fordforums.com.au/showpos...2&postcount=48 clean these first mate i used to do it every month as routine and never stopped getting the 500's to the tank..
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr Last edited by au11futura; 29-10-2011 at 10:55 PM. |
#6 | |||||
3..2..1..
ive been meaning to throw some new discs and pads at it for ages now, has that dreaded warped disc steering wheel shimmy, so i might just order new plugs and leads/coil at the same time, spend a weekend doing some maintenance on the old slapper. |
#7 | |||
[SIGPIC][/SIGPIC]
#8 | |||
3..2..1..
sounds like a replacement is in order then. have a look at this http://www.ebay.com.au/itm/FORD-Falc...item231599e1c9
[SIGPIC][/SIGPIC]
Was this problem fixed?
