Old 31-12-2011, 12:13 PM   #1
El Caballo
Token American
El Caballo's Avatar
Default Damn vandals, radio antenna replacement help?
Some idiot decided one of his last acts for 2011 would be to tear the antenna off of my AU. It is a power unit that wouldn't go all the way down, still worked otherwise and there is no excuse for such thoughtlessness. But I digress...
I looked in my Max Ellery manual under the body section and it had the helpful sentence "If necessary remove radio antenna." Yeah, thanks.
Looking at the car though it appears that I could remove the top fender/wing/guard bolts and the metal should be flexible enough for me to get in there. Getting the antenna out may be another matter.
Has anyone done this procedure without having to remove the front bumper cover and the fender? How did you do it?
Here is a picture of a Ford power antenna that appears to have a bracket on the bottom. I'll probably fix it with the rope and antenna replacement bits.
El Caballo is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2011, 01:02 PM   #2
El Caballo
Token American
El Caballo's Avatar
Default Re: Damn vandals, radio antenna replacement help?
Upon further research elsewhere it appears that I won't have to take much apart after all. I'll do the deed and post pics later.
Old 31-12-2011, 01:27 PM   #3
crakrz
T3 TE50 Blueprint
Technical Contributor: For members who share their technical expertise. - Issue reason: Craig has shown and shared an outstanding amount of knowledge in the field of Tuning. Craig is only to happy to share with anyone that asks his knowledge on the EEC tuning system, in particularly in the use of Moates Quarterhorse and Binary Editor.
El Caballo, I will be very interested in your progress, as I had a galah flew straight into my aerial on the way to work this morning and was wondering how difficult the job would be.
-Craig
crakrz is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2011, 03:16 PM   #4
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Try here
http://www.fordmods.com/documents.php?d=69
UK
Old 31-12-2011, 05:23 PM   #5
El Caballo
Token American
El Caballo's Avatar
Hey crackrz, I'll hook you up in another thread. Funny, I went to fordmods and got some really good info there before you posted.
