Old 01-01-2012, 01:27 PM   #1
Barnzey
Barnzey's Avatar
Default Cruise Control Manual
Happy New Year to All
I am install a cruise control kit I get from FTG and just need a little help to confirm that the clutch switch is depressed when clutch is not push in.
And mounting it straight on to steel bracket near cluch pivot point.
If poss a picture of the switch on the bracket would be great.
If not asking to much on new years day
Thanks
Barnzey is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2012, 08:59 PM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: Cruise Control Manual
Yes that is rite, switch is closed when pedal is in the up position
Originally Posted by Riksta
Old 01-01-2012, 09:52 PM   #3
Barnzey
Barnzey's Avatar
Thanks For that Whoosha.
Old 02-01-2012, 10:36 AM   #4
rowan194
Ok, now I'm curious... what happens when you hit a hill in a manual with CC on? Does the engine just surge to max revs?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2012, 10:49 AM   #5
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
If your car has enough power/torque, then it'll just pull up the hill in the gear your already in...
If you want to downshift for the incline, then you just pop the clutch in, shift down, let the clutch out and the cruise control picks the car speed back up to what you were previously doing..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2012, 10:53 AM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
Why would it do that ? it maintains the speed of the gear it was set at. ; 100 Ks in 5th aprox 2250, or 2650 app. in 4th still at 100 Ks . Disengaging if the clutch is depressed .
Old 02-01-2012, 12:04 PM   #7
Donny
Tickford 220kw Windsor...
Donny's Avatar
Mine must be slightly out of adjustment, when i used to tap the clutch pedal in my GT-P it would disengage the CC instantly..
In the XR when i tap it, nothing happens, Iv actually gotta partly press the pedal in maybe 1/4 of an inch and then it slightly picks up a few revs, maybe 200 or so from where it was and then disengages..
To re engage it, you have to hit the resume or set buttons again, it dosent automatically resume after you hit or depress the brake pedal or clutch pedal.
1972 Falcon XY GT 351 Clevo 4V Big Port, 4 Speed Top Loader Manual, Ice Blue....
2002 Tickford AU Series III XR8 220kw Windsor, 5 Speed Manual, Liquid Silver...
Donny is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2012, 10:05 PM   #8
MarkT83
MarkT83's Avatar
it would do the same as if you hit the brakes it would disengage cruise you would have to hit set for it to engage.
MarkT83 is offline   Reply With Quote Multi-Quote with this Post
