Old 03-02-2012, 04:00 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default alternator light comes on sometimes?
as the name suggests my alternator light comes on when i shift at redline a few times in a row.
its never done it before. but after putting a new alternator on about 2 months ago its done this some times. if i turn the car off and turn it back on it doesn't happen. why is this any ideas? i've not really checked it but going to tonight was gonna make sure connections good but other then that i have no idea.
hthanks
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 03-02-2012, 05:40 PM   #2
shayne93
66 Mustang
shayne93's Avatar
Default Re: alternator light comes on sometimes?
Is your P/S hose leaking onto it. Used to happen to me in my old AU Ute, battery/alt light was an early sign of alternator going to **** it self
shayne93 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2012, 02:53 PM   #3
Day-mow
rexnet
Day-mow's Avatar
Yes I know this but I replaced ye unit 2 months ago. And it's never done this before.
Old 04-02-2012, 04:54 PM   #4
mik
mik's Avatar
another possibility, when you give it heaps, and the engine is twisting in the mounts, the wiring or a plug has a fault, and when it moves or stretches slightly because of the engines movement it`s causing the light to come on.
Old 04-02-2012, 05:08 PM   #5
burnz
VFII SS UTE
burnz's Avatar
i was going to say brushes, thats the norm for a intermitant...
other wise im stumped..
the only thing i recomend if you love to red line, is underdrive the alternator..
as it is now overdriven 65%!!
GO SOUTHS
Old 04-02-2012, 06:37 PM   #6
Day-mow
rexnet
Day-mow's Avatar
im not 100% sure what you mean by underdrive?
ahh yeah so just double check all wiring etc?
Old 04-02-2012, 07:32 PM   #7
burnz
VFII SS UTE
burnz's Avatar
ok.. at 6000 rpm your alt is doing around 9,900 rpm..
underdrive means just that say 25%.. 6000 rpm crank speed could mean 4000 rpm for the alterantor
GO SOUTHS
Old 04-02-2012, 08:14 PM   #8
Day-mow
rexnet
Day-mow's Avatar
oh hecktik. how do i change that?
Old 04-02-2012, 08:45 PM   #9
burnz
VFII SS UTE
burnz's Avatar
i wouldn't unless you live on the rev limiter,
your pully ratio is setup for idle~2500 rpm for good charge, above this is a waste..
underdrive and your battery will go flat unless you drive 90% of your time above 4000 rpm (motor sport)
GO SOUTHS
Old 04-02-2012, 09:43 PM   #10
Day-mow
rexnet
Day-mow's Avatar
Oh. So then really I should be looking for loose connection etc?
Old 05-02-2012, 09:40 AM   #11
mik
mik's Avatar
you have to start somewhere, check the plug in the back of the alternator is in properly, the screw on fitting is tight, i`d even check battery terminals are clean, any wiring that`s flopping around, or anything out of the ordinary even the engine block earth is secure, you know just a 5 minute check, if you find something ..............good, see how it goes, if you find nothing maybe think about other avenues.
Old 05-02-2012, 05:39 PM   #12
Day-mow
rexnet
Day-mow's Avatar
sounds good.
cheers mang
Old 05-02-2012, 06:47 PM   #13
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Also have a good hard look at your belt tensioner, if the spring's a bit weak it could be allowing belt slip when flat out.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2012, 10:28 PM   #14
Day-mow
rexnet
Day-mow's Avatar
true. i need to replace my belt anyway. 200k km. pretty sure its tensioning quite well though.
Old 16-06-2012, 07:34 PM   #15
Day-mow
rexnet
Day-mow's Avatar
well this is still a problem.i've changed the belt so maybe it is the tensioner. but its only when i push it after about 4,500 consecutively and my volts start going down from about 14 where it sits normally. and then when you calm down and drive "regularly" again it goes back up for 14.
any further thoughts?
Old 16-06-2012, 07:56 PM   #16
dieseltrain79
Poor battery terminals ?
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2012, 08:08 PM   #17
4ford
If you could rig up a multi-meter to show the alternator FREQUENCY at the battery terminals, whilst you are flogging this car, then that would tell you if the alternator RPM is actually slowing at these high engine RPMs, which would then give you the decreasing output voltage you speak of...
Would only take a couple of wires jury-rigged into the cabin on a tempory basis.
Remember, the alternator light on the dash is a simple light that shows up only when the battery voltage exceeds the alternator output voltage....simple.
If the alternator RPM IS slowing, then its drive mechanism is at fault!
Good Luck...
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2012, 08:56 PM   #18
mongrelEF
Bugger!
mongrelEF's Avatar
Alternatively, just stop flogging it
Old 17-06-2012, 10:10 AM   #19
dieseltrain79
Maybe the light is on from overcharging ? Due to spinning to high revs?
Old 17-06-2012, 05:16 PM   #20
4ford
Ehhh...the light would not illuminate in this case, you would simply overcharge and boil the battery, followed very shortly by battery failure.
4ford
Old 17-06-2012, 05:39 PM   #21
dieseltrain79
Wouldn't the charge light come on due to high voltage and not only low ?
Old 17-06-2012, 05:50 PM   #22
BHDOGS
Could it be a battery on the way out?
Old 17-06-2012, 09:04 PM   #23
Day-mow
rexnet
Day-mow's Avatar
i have an XR6 so i can see the volts coming down then the light comes on. ease up and it builds back up to 14.
battery shouldn't be on the way out its about 18 months old.
4ford. what setting would i need to do this?
Old 18-06-2012, 11:42 PM   #24
mongrelEF
Bugger!
mongrelEF's Avatar
The charge light only comes on when the field is not active - not charging.
Assuming it's not getting belt slip, you're probably experiencing brush bounce. At extreme RPM, the brushes can bounce off the slip rings and collapse the field = no charge. New brushes would likely alleviate the problem until they wear down.
Bottom line - nothing attached to almost any factory street engine was designed with high RPM in mind. It'll do it, but won't like it.
Old 10-10-2012, 09:29 AM   #25
Day-mow
rexnet
Day-mow's Avatar
Ended up being a faulty alternator.
Although I replaced the auto tensioner pulley as well
