Old 29-07-2012, 08:14 PM   #1
fordman302
fordman302's Avatar
Default Trick Flow streetburner
Hi all, after allot of research i have found myself fairly keen on grabbing myself a streetburner manifold from summit racing, just wondering if anyone else has one of these and any dramas or issues they had fitting them up, i want to educate myself fully before i order it so i can make sure i get all the bits required, thanks in advance
Nathan
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 08:45 PM   #2
BOTTLEDUP
Default Re: Trick Flow streetburner
Honestly I don't think that the performance gain you will get is worth the expense of firefighting one of these in. Compared to the Explorer intake you have now I doubt you would see any major gain in horsepower.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 29-07-2012, 09:01 PM   #3
fordman302
fordman302's Avatar
I need to open up the intake to match my heads, I have 200cc roush/world sr's on it, the cost isn't actually that bad, landed for about 640, plus I want some other bits that I will probably put in with it
Old 31-07-2012, 02:42 PM   #4
Cam
Stroking it...
Cam's Avatar
What throttlebody are you planning on running?
Also, if you are using aftermarket valve covers, factor in a phenolic spacer for the manifold as the throttle linkage fowled my Ford Morotsport covers..
Had: 347ci AU
Then: Stock AU fairmont wagon...'05 AWD Terri GHIA on Gas.. and a caravan..
Currently traveling OZ Travels over, follow me at http://Facebook.com/gonecaravaning
Now: Busted assed EB Wagon - 5sp and Dual Fuel.
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2012, 06:19 PM   #5
fordman302
fordman302's Avatar
I have a tickford 70mm throttle body, i also already run a spacer on my factory manifold and was fairly set on the idea of putting the 3/8 spacer in, you can get 1" as well but im thinking that would put it all to high under the bonnet?
Old 31-07-2012, 06:22 PM   #6
Cam
Stroking it...
Cam's Avatar
I had no issues with bonnet clearance, but mine was machined flat.. I am fairly sure there's a fair bit of room to play with there..
Had: 347ci AU
Old 31-07-2012, 06:24 PM   #7
fordman302
fordman302's Avatar
is yours an inch? have you got pics at all?
Old 31-07-2012, 06:44 PM   #8
Cam
Stroking it...
Cam's Avatar
It was a 1/2, but is sold so no pics of the spacer itself, buy it and gaskets from summit..
Had: 347ci AU
