Old 20-09-2012, 12:18 PM   #1
markxr6t
Default AU II XR8 Rough Idle Troubleshooting
Hi all
Have an AUII 200kw XR8 auto on dual fuel. Just last week I was thinking how beautifully smooth its idle was, particularly on gas. But now.... Heres my issue.
  • Starts fine. Rough idle, almost stalling, in all gears PRND
  • Rough idle on both petrol and gas
  • Stalls frequently when cold, just runs rough when warm but doesn't quite stall
  • Problem started after running low on gas. Was hard to start and poor idle began (May have backfired). Idle got better next time I drove it but has been permanently crap since.
  • Plugs are 10000km old platinum so I suspect they're fine
So the problem seems to have started after running low on gas and a possible backfire (or other one-off noise under the bonnet), but now effects petrol and gas.
Have just spent a couple hours searching so I know all the things it could be, but I just want to know the order I could check things in as I don't want to go buying new sensors if they're not the issue.
I also have an AU3 220 I could change out parts / sensors with if necessary.
Any ideas?
Thanks for any suggestions.
Mark
markxr6t is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2012, 03:25 PM   #2
portokatsiki
Default Re: AU II XR8 Rough Idle Troubleshooting
If there was a backfire there would definitely be a vacuum leak somewhere. I would check the gas mixer for any leaks also the rubber hose going from the gas mixer to the throttle body and any other hoses connected to the gas mixer.
portokatsiki is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2012, 10:53 PM   #3
Gaz
Got Ghia?
Gaz's Avatar
Any major missing when cold? if so join the club...
http://www.fordforums.com.au/showthread.php?t=11366152
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2012, 04:16 PM   #4
markxr6t
Problem solved! It was a vacuum leak - a small rubber pipe hooking into a plastic elbow directly behind the engine - part of the lpg setup I think. Plugged it back in and now she idles like a Lexus again (well, not quite but good enough)
My Manual Series III 220 misses on acceleration and farts and kicks when cold but once it warms up its fine. I can live with that.
Old 24-09-2012, 04:18 PM   #5
markxr6t
Thanks mate - now that I've re-read your post you were exactly correct with the rubber hose to the throttle body diagnosis Good on ya!
