24-09-2012, 07:13 PM | #1 | ||
2mny projects 2 lttl time
Hi Guys. Bought an AU ute and the left blinker is going at a million miles an hour......I know this is a usual sign of one blown bulb....but not in this case, as all the blinker lights are flashing, just three times as fast as they should.
Its not the flasher unit as I've swapped it out for a known good one. (handy to have a spare full car to work with) Any ideas much appreciated Cheers Keith |
24-09-2012, 07:29 PM | #2 | ||
So the front, side quarter and rear lights are working?
Putting it out there in case this has some effect too... is the cluster indicator also flashing? Try progressively disconnecting the indicator lamps to see if there's any change in behaviour. Maybe you have a dodgy bulb. |
24-09-2012, 09:04 PM | #3 | |||
It was after I fitted an aluminium tray and I remember that on the passenger side I "commoned" the earth wire of the blinker with the earth from the taillight, at a terminal block, as the actual light fitting that was attached to the tray had a common earth, so only one earth source needed. I wouldn't mind betting this is somehow interfering with the flasher circuit on that side. Will try disconnecting the original left blinker earth from use, as I did with the right side, (which is working fine) Will update tomorrow. |
24-09-2012, 09:47 PM | #4 | |||
Connected each of the two individually and there was no change Still looking...... |
24-09-2012, 09:49 PM | #5 | ||
Check and clean your trailer plug connector if you have one, has happened to me before.
24-09-2012, 10:35 PM | #6 | ||
Hi. Are they LED tail lights (and blinker), If so they will need a load resistor across the lamp. Or it may just have the wrong globe in the l/h/r lamp. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
25-09-2012, 04:43 AM | #7 | |||
Will check this and report back |
25-09-2012, 04:45 AM | #8 | |||
25-09-2012, 11:07 AM | #9 | ||
Got Ghia?
Yep, a fast blinker is a sign of more current draw than rated (and lowered resistance in circuit). IE to higher wattage globe
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold 2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers |
25-09-2012, 05:55 PM | #10 | ||
Yathink?
25-09-2012, 09:03 PM | #11 | ||
Huge thanks to all who replied
Problem is now sorted (after a few false starts) It WAS a bulb of the wrong wattage in the rear blinker that caused it (now replaced) Thanks again guys, Keith. |
26-09-2012, 10:45 AM | #12 | ||
So you had a 5w bulb insted of a 21?; that'll do it.
