Old 07-10-2012, 12:54 AM   #1
xr6tjet
[AUT-747]
xr6tjet's Avatar
Default AU Falcon Boot Rattle
Hey,
So I've got a dual sub setup in my boot and when I power up the system I get a massive load of boot vibration. Now I've got the numberplate done, when I press on the boot garnish, pushing towards the car the boot rattle goes away. Besides dynamat which I already know is a remedy. What else could be recommended to get rid of majority of the vibration?
Cheers, Alex
xr6tjet is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2012, 03:18 AM   #2
robbyj
Rob
robbyj's Avatar
Default Re: AU Falcon Boot Rattle
expandable foam stuff.
my mate has duel subs in his ef that shake the entire shed, expandable foam, dynamat, and a boot carpet thing see's virtually no vibrations.
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 07-10-2012, 03:40 PM   #3
xr6tjet
[AUT-747]
xr6tjet's Avatar
Where abouts do you spray the foam into? and dynamat all over the boot yea?
Old 07-10-2012, 05:27 PM   #4
robbyj
Rob
robbyj's Avatar
the gaps between the metal, should be able to see where the holes are and all that, then cover with dynamat, the whole boot lid, then put a carpet over it.
Be sure you figure out how the carpet goes on before you foam it and dynamat it.
Start spraying the foam as far down as you can, then work your way up. Iv personally never used the stuff so thats about as much info as i can give ya. But it works well.
Old 14-10-2012, 09:24 PM   #5
scottichaos
be very careful using the expanding foam around the boot garnrish/boot lock as it can jam up the lock and ya boot wont open(from experiance)
also be careful of over spray with the foam as it stick like hell to anything and everything. jaycar sell sound deadener for about 30 bucks a roll and it works exacly the same as the dynomat.
scottichaos is offline   Reply With Quote Multi-Quote with this Post
