Old 09-10-2012, 03:13 PM   #1
millzy555
Default Identification of part?
Hi guys i have an oil leak from this place (can see it dripping when car is on). What is this part?, is it replaceable, how hard etc?
Car is an au3 xr8 (windsor engine)
millzy555 is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 05:26 PM   #2
BZINGA
Powered by Ford
BZINGA's Avatar
Default Re: Identification of part?
Oil sender?
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 09-10-2012, 06:09 PM   #3
BHDOGS
Yup definatly looks like the sender they are know to leak eventually
Old 09-10-2012, 08:43 PM   #4
millzy555
Cheers for that! Simple fix of out with the old in with the new?. Will search up on it
Cancel that, looks to be a common problem/ easy $20-$30 fix
Old 11-10-2012, 09:27 PM   #5
millzy555
Well it turns out it was the sender...$60 from fraud. Now after putting it in the oil pressure is zero and the light is on....This one is a lot larger than the original. Did i just get sold the wrong part??
Old 11-10-2012, 11:46 PM   #6
BHDOGS
There are two different ones I'd say this is the wrong one take your old one to ford and match it up
Old 12-10-2012, 09:39 AM   #7
bartsau
bartsau's Avatar
The low series I believe have an oil pressure switch rather than sensor. I tried putting a sender in my forte and it read 0. Put the switch back in and read normal.
I think you need a high series BEM or ECU in order to actually get the sender to work.
So fraud have I believe given you the wrong part.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2012, 01:10 PM   #8
T3man
T3man's Avatar
you need an oil pressure switch; not sender.
