Old 15-11-2012, 05:32 AM   #1
btf-ford
Default Sagging roof headlining
hi. the roof lining on my ford Festive has began to sag.
The lining design is suspended and not a fabric glued to the roof. Held up by a wire rod.
I am not sure if a clip has come loose or what ever. Any information on how the roof lining is held up and any tips in having it repaired.
I have tried doing a search but without luck. It seems as if the support rod has popped out or a gust of wind got under the liner and popped it.
I have tied to search information on how the liner is held up and any installation tips but without success,
Thanks in advance
btf-ford is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2012, 09:08 AM   #2
Fiesta_Man69
Default Re: Sagging roof headlining
Model? Year? Festiva or Fiesta?
Fiesta_Man69 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2012, 09:12 AM   #3
Russ
Russ's Avatar
Hi, not sure what year model you have but I came across this which I thought might be useful for you, http://autos.groups.yahoo.com/group/.../message/14071 if you're confident tackling the job yourself then hopefully it might get you out of trouble, if not I would suggest trying a motor vehicle upholsterer / trimmer and getting a quote from them to repair it for you
Old 15-11-2012, 09:16 AM   #4
Russ
Russ's Avatar
He does say Festiva (Festive actually )
Old 15-11-2012, 10:27 AM   #5
Fiesta_Man69
Yes, wasn't sure what a Festive was.... It is almost Xmas tho
Old 16-11-2012, 06:56 PM   #6
btf-ford
Yes it is a 1997 ford festiva (sorry typo before) i looked at the link provided a above, thanks.
It was not that clear. I m wondering if he plastic clips that hold one roof lining wire has come out. I am it sure as I wold have o remove he whole liner to look at it. I was oping someone it give me a heads up description as to how he liner is connected and what to look for. I can get at the wire and the clips by removing the door seal that holds the liner in place but I am to sure what I am looking for. I can only partially access the clips and the wire but not sure were and how they connect to the car. I can try and look at one next time I am at the wreckers.
Is there any diagrams or phosphor showing how the lining is connected? Thanks again
