Old 27-04-2013, 11:46 PM   #1
93EB_SXR6
I totalled my XR6
Default Auto > manual conversion labour. Good price?
I have been contacted by somebody who is willing to convert my car from auto to manual for $500 labour (I will be supplying all parts).
Is this a good price? I don't know if this person is a qualified mechanic or anything like that.
Cheers.
93EB_SXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2013, 12:52 AM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: Auto > manual conversion labour. Good price?
That sounds about right. Is that including fitting the pedal box etc?
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2013, 09:39 AM   #3
93EB_SXR6
I totalled my XR6
Yeah it will be for the full conversion.
Old 28-04-2013, 06:56 PM   #4
trick_xd
I build your wish list...
trick_xd's Avatar
That's priced out at to much
At 77 ph on bigger jobs like this
Your looking at 1.5 to remove and refit the dash
.5 remove and refit pedal box
1 remove auto ect ..
1.5 to fit manual and adjust
People just want to charge you big money as it is time consuming
as they could do a easy service and charge out there time at 100 ph
If it weren’t for physics and the law enforcement, I’d be unstoppable.
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 28-04-2013, 11:15 PM   #5
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Don't have to remove the auto pedal box just use the mal wood pin kit which adds the clutch pedal to the auto pedal box so no removal of dash required
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 30-04-2013, 12:25 AM   #6
trick_xd
trick_xd's Avatar
Yep ya can do that ...
Mal wood kit is just under 100$
So saves time and cash
Old 30-04-2013, 01:48 AM   #7
93EB_SXR6
I totalled my XR6
Thanks for the insight, I will get as many mechanics to quote the conversion as I can
I am indeed planning on using the mal wood kit to modify the auto pedal box, I was considering using a manual pedal box because there is one in the kit but it isn't worth pulling the dash out to fit it.
I may still do the conversion myself but I don't have the facilities for it and I'm not keen to get a mechanic to fix whatever botch job I inevitably create.
Old 30-04-2013, 01:30 PM   #8
trick_xd
trick_xd's Avatar
The only problem with going the Mal wood kit is after some time you will crack the pedal box and it will need to be pulled out and strengthened
It is a common thing even on manual boxs
Old 01-05-2013, 02:06 PM   #9
93EB_SXR6
I totalled my XR6
I have heard about the problem with the manual pedal box cracking but I'm going to try to reinforce the auto pedal box when installing the mal wood kit.
The conversion may have to wait a couple of months any way, got a lot of bills at the moment :(
Old 02-05-2013, 01:43 PM   #10
trick_xd
trick_xd's Avatar
The only way to reinforce it is to Weild a plate or large washer right where the pin goes
Old 02-05-2013, 07:45 PM   #11
93EB_SXR6
I totalled my XR6
Thanks for the info, I'm sure it will come in handy when the time comes
Old 02-05-2013, 11:02 PM   #12
trick_xd
trick_xd's Avatar
While the dash is out get a plate wielded on the inside of the fire wall where the clutch cable goes that will help a heap
