Old 01-06-2013, 09:23 PM   #1
MrEL
Sick Puppy
MrEL's Avatar
Default GT40P and Trickflow Head Rocker Compatability?
Hi all
Seriously considering swapping my GT40P heads over to a set of Trickflows twisted wedges.
http://www.summitracing.com/parts/tf...view/make/ford
The GT40P currently have a set of the Yella Terra 1.7 Roller Rockers on them.
Will The roller rockers swap over or will I need to buy a set of Trickflow rockers?
Just trying to work out what bits Im going to be needing before I commit to it and jump in feet first.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2013, 11:28 AM   #2
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
Default Re: GT40P and Trickflow Head Rocker Compatability?
From the YT website, although it does not list the Trickflow Twisted Wedges, most of the aftermarket valve spacings are at least 0.01 of an inch wider, so it will depend on the valve spacing on the Twisted Wedges.
http://www.yellaterra.com.au/downloa...entIdentity=26
If the twisted wedges have the same valve spacing as the AFRs etc, then you will need to buy longer shafts for your YT rockers. Part number for the longer shafts is YT 5048 and still available from YT.
Some good information in this thread here. It is about AFRs, but a lot of the part numbers etc listed.
http://www.fordforums.com.au/showthread.php?t=11268872 The last two pages have some YT detail that I discovered when doing my AFR upgrade.
I believe XH5LWPN is running some Twisted Wedges on his 5.6L Windsor. He may be able to answer your question straight up. Send him a PM.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2013, 12:22 PM   #3
fordman302
fordman302's Avatar
I notice it comes with rocker studs already installed, the person who did the work on my car previous to me buying it put a set of stud mount heads on and then machined and packed it up to fit pedastool mounts and made an absoulute mess of it, spent some money fixing them. I ended up banging a set of these in
http://www.ebay.com.au/itm/FORD-289-...item5d3faa2abb
they seemed good value or if you are ordering from sumit you could probably grab a set of them to
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2013, 12:26 PM   #4
fordman302
fordman302's Avatar
oh im just making the assumption that you have pedestal mounts on your gt-40's
Old 04-06-2013, 07:52 PM   #5
SILENT_RAPTOR
His yt rockers wont work on the tfs heads, gt40p's are pedestal mount where as tfs are stud mount very very different mate.
AU1 XR8 btr
GT40p setup
14.341@95.91mph
TFS 185 heads setup
13.853@100mph
Baby 60-1 t4
11.7@121mph 12psi
SILENT_RAPTOR is offline   Reply With Quote Multi-Quote with this Post
Old 04-06-2013, 11:16 PM   #6
SVT8
SVT8's Avatar
With the twisted wedge heads you will need some offseted rockers to suit the design of those heads. Your convential rockers wont geometrically be correct on the tw heads. Harland sharp do offer an offseted trickflow tw head rocker set
SVT8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-06-2013, 08:24 AM   #7
BOTTLEDUP
In short the factory Yella Terra rockers will NOT bolt onto the TFS heads.
Sell your GT40Ps & rockers together, you will also need new rockers, pushrods & rocker covers.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
