Old 15-07-2013, 10:36 PM   #1
car10002
Default homebuilt caravans and trailers
hi
what is required to register a homebuilt teardrop caravan in sa and does the chassis need engineering and can the chassis be engineered before the timber walls and roof put on.
someone said the homebuilt caravans or trailers have to be engineered by a engineer
does the chassis have to be engineered with the walls and roof or can just the chassis be engineered before the walls and roof go on.
is it possible to just weld a number on the drawbar and say its a old caravan with same owner or unknown owner and/or theres no number plate and needs a new rego number or even moving the number plate over fron a rusted out caravan and just tell them you repaired the chassis to minimize problems getting a homebuilt chassis registered
to minimize problems with the gas and 240v can you register it first then get them done if you make up a number for the chassis and say its a old vehicle
car10002 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 07:17 AM   #2
hoodedaxeman
Default Re: homebuilt caravans and trailers
For your own peace of mind,and everyone else's.
It would be best to have it engineered and certified.
hoodedaxeman is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 07:57 AM   #3
The Yeti
The Yeti's Avatar
It's just a closed in trailer so it's registered as such weigh bridge cert and blue slip and away you go
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 08:08 AM   #4
Sox
RIP...
Sox's Avatar
That's how it is in NSW, dunno about SA.
Caravans are classed the same as a box trailer.
The gas will need inspecting by a gas dude though.
Oval Everywhere...
Old 16-07-2013, 08:49 AM   #5
sgt_doofey
sgt_doofey's Avatar
http://www.sa.gov.au/government/enti...+SA/Contact+us
That's probably the best place to ask.
Cheers,
Sam.
Old 16-07-2013, 10:01 AM   #6
Jason[98.EL]
Jason[98.EL]'s Avatar
have a look at this it tells you what is required
LOOK AT ME
hope that helps
as for the gas side you can get hoses and the likes made up to suit what you need
Jason
[SIGPIC][/SIGPIC]
Old 16-07-2013, 10:14 AM   #7
car10002
What about if the trailer or caravan has a chassis number but no number plate and was made before 1989 or if it doesn't have a chassis number or rego plate and is a pre 89
Old 16-07-2013, 10:46 AM   #8
pottery beige
Ring the dudes at Regency Park.. the answers you seek are not here....
pottery beige is online now   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 01:14 PM   #9
blackf6
R51 Pathy, 91 Jayco Swan
blackf6's Avatar
I yelled out the window to some Grey Nomads on the way past. They didn't have a clue what you were on about. ?????
blackf6 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 02:45 PM   #10
RJ94
No inspections required if you do every thing with 12v. If you want a gas stove try a metho burner.Plenty hot and safer.
RJ94 is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 06:32 PM   #11
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Yeah, but believe me 12V can still be deadly, all you need is an unfused wire to rub through, eventually, especially if you are sleeping in the back and it catches fire.
I've personally done electrical work through work that set a vehicle on fire, luckily only an engine bay fire, melted a battery, burnt up the pollen filter housing and destroyed some wiring, rather than total loss of vehicle.
It doesn't take much.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 09:48 PM   #12
ebxr8240
Performance moderator
ebxr8240's Avatar
Aha I'm slowly becoming one of those..
Not so grey though... Lol..
Bought a converted Fuso bus..
Daily driver GTE FG..
