Thailand Specials
Hey guys, I've got the opportunity to buy a 5.9L Cummins 6BT from a train fairly cheaply, they have been used as a generator from what I've been told.
These engines were also used commonly in Dodge RAM in the USA, is there any legislation that would be holding me back from using it in a vehicle? Its a common conversion for those big American utes like F series/Silverado/RAM etc. So far the differences are fuel pump I'm fairly sure, the rest of the engine is the same as the automotive version. The year of the engine is 2003 ranging up to 2009 of the ones I have been offered, the vehicle in question is 2000/2001. |
My guess you would have to get the car engineered and to pass all EPA requirements. Maybe speak to Vic roads or an Engineer.
#3 | |||
Thailand Specials
Are there any engineers in Victoria who I can call to ask about this? |
I think xisled is suggesting and I believe it to be so over here that even tho the vehical still runs the same type of fuel being a newer type vehicles motor it may need to comply to newer emission regs , and another thing you may need to look at is if its a larger capacity motor you may still need it engineered as well
yes still (as money n time permit) doing the rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually just remember don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic! I have taken up meditation... at least it's better than sitting around doing nothing !! |
#5 | |||
Thailand Specials
I'd be going down from 6.5L V8 to 5.9L I6, both turbo diesel. |
#6 | |||
If I was you I would investigate the pump differences, if any, as getting the correct pump could be very expensive and it is likely that you would be able to modify the pump fitted to that engine. You need to speak to a Cummins expert. It may be possible to set the pump for automotive use. My knowledge of Automotive vs Industrial and Tractor diesel engines is limited to Ford 590E, Ford Dover and Ford Dorset. I have twelve of them, lol. Steven |
Cam shaft could be different to suit the RPM range too.
The Silver Bullet - BJ74 Where the actions at Ontrack 4wd Club https://www.facebook.com/ontrack4wdclub |
#8 | |||
Thailand Specials
You are right about the pump, they spin at X RPM, so the pump will no doubt have to be changed. I've got pick of about 30 engines so far. On this one the pump appears to be at the front of the engine, but look at the oil filler neck and dip stick: ![]() You could extend those to be up the top, right? |
#9 | |||
Good luck with it though... |
2 users like this post: |
#10 | |||
My experience with the Ford engines I play with is they are used in trucks, tractors, industrial (compressors, pumps, combine harvesters and gen sets) and boats. All have different speed control requirements. |
#11 | |||
Chevy badges , the Polariser of the new millenia . |
#12 | ||
trying to get a leg over
![]() Join Date: Dec 2004
That is the 1st generation 6BT Cummins which is full mechanical and uses a Bosch rotary pump, the later type were the ISB which used a Bosch high pressure pump and different injectors and the latest type is still a ISB but uses common rail and full electronics.
Would be easy to change that from industrial to automotive spec I rekon.
Cameron ------------------------------------------------------ |
U can change the oil filler and dipstick locations easily, these motors were made to fit a variety of things, case tractors had them fitted, Blaw knox asphalt pavers had them too.
There should be a aluminium tag on the top of the timing cover with the specs on it.
#14 | ||
Thailand Specials
Might be the goer I reckon, these mechanical diesels pretty much just need power to their fuel shutoff solenoid and thats about it to get her running.
So minor modifications and she will be good to go, I'm seriously considering purchasing one as i can get it for a real good price. Even if it doesn't go into one of my cars for a while, its a good project. |
#15 | ||
Damo I'm looking at these also.
If you swap the rotary pump for a p pump you have to change the injectors too they operate at different pressures. |
#16 | ||
Broken
How many hours have these engines clocked?
What do they want for them?
The Scud GT 11.4 @ 128, 1.88 60ft. |
#17 | ||
Thailand Specials
The 2003 models are $1750 with one rebuild already done up to $2650 for a 2009 model with no rebuilds.
#18 | ||
Thailand Specials
Here is a pic of prices:
![]() I put down cash on a 2003 one, so minus 1 from the list ![]() I can give you contact details via PM if anyone is interested in one. |
