10-06-2014, 12:15 PM | #1 | ||
Chucked some king super low's on the back of my XR8 to try and remove the 4wd height...but it's only like 10mm lower max (needs another inch), it looks about 'low' height not super low. Left is standard springs and right is superlows...How low do super lows usually sit on an AU?
ED XR6, LeMans Red, 5-Speed AUII XR8, Silhouette, 5-Speed Last edited by shyun; 10-06-2014 at 12:25 PM. |
10-06-2014, 01:16 PM | #2 | ||
Racing improves the breed
That looks far too high for super low's. They didn't give you the wrong springs did they? Have you gone for a drive to let them 'settle'?
1970 Mini Cooper S Historic Group Nc Touring car 1964 Mini Cooper S Historic Group Nb Touring car 2024 Subaru Outback Touring XT Victorian Hill Climb Championship |
10-06-2014, 01:32 PM | #3 | ||
Yeah part number checked out, it has SL at the end. That's after a drive so theyre not going to drop anymore unfortunately
ED XR6, LeMans Red, 5-Speed AUII XR8, Silhouette, 5-Speed |
11-06-2014, 09:03 AM | #4 | ||
5.6L x 2 pilot
If they where new springs, they will settle a bit more with use. Is that a 17" rim with a lower than standard profile? Having a small wheel diameter will definitely make it harder to fill the wheel arch.
Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
11-06-2014, 09:13 AM | #5 | ||
They look like Rebel rims, which are 18" aren't they?
11-06-2014, 09:21 AM | #6 | ||
5.6L x 2 pilot
There is a 17" version. I believe that they where on Fairmonts? I guess we will find out soon enough?
Stu
11-06-2014, 09:35 AM | #7 | ||
My old Au xr had to be lowered twice for this same reason. King spring sl did nothing in the rear, I had to use ssl to make it sit like I wanted to. So sl for front and ssl for rear on xr
Build Thread: BA XR8 with all the goodies. fordforums.com.au/showthread.php?t=11247663 |
11-06-2014, 10:49 AM | #8 | ||
Yeah theyre 18" rims off rebel/TS50, probably just look small cause its sitting too high! but looks like i'll have to go ultra lows then.
Maybe the upper shock mount makes the car drop down when it starts to break, mine seems pretty solid still.
16-06-2014, 12:14 AM | #9 | ||
Well I swapped them for some ultra lows so will get some pics up for comparison when they're in!
16-06-2014, 06:55 PM | #10 | ||
Walking with God
Hate to be a killjoy, but I like the height! LOL!
Will look forward to before and after pics though. GK
16-06-2014, 07:03 PM | #11 | ||
I had the same springs in the rear of my xr8 and it started at that height and 12 months later the tyre is now level with the guard, so it sagged 2" in 12 months,
18-12-2015, 12:52 AM | #13 | ||
Bit of a late update! I got SL springs for the Front as well, which actually raised the front marginally, now it is roughly the same as the back with SSL. The SSL probably only dropped another 10mm or so over the picture of the SL.
Handling wise, it seems a little understeery. The SSl rear are quite a bit softer based on the specs that I found. 310-365lb progressive (King) vs 470lb fixed (Tickford). Now the interesting part is in the king catalogue, rear superlows are ACTUALLY SSL, unlike E-series. That might explain the heights of everything I've found! It still sits a bit high for my liking, my ED has superlows and it is a good 10mm lower. Seems like coilovers are the way to go eventually.
18-12-2015, 07:42 AM | #14 | |||
As far as how much lower they went- there was only about 10mm in it when I first had them installed with new adjustable Konis but I'd say they've probably settled another 10mm by now (almost 3 years later). The car drives very well and is noticeably flatter mid-corner on the circuit. |
18-12-2015, 10:37 AM | #15 | |||
28-12-2015, 06:17 PM | #16 | ||
Afterburner + skids =
This is my XR8 on SL front and rears. I recently went back to Lows in the rear, but stuck with a progressive wound coil by Dobinson springs.
29-12-2015, 10:11 AM | #17 | ||
RAGE Engineering
Funny, I put on some King Lows on my AU and they were *way too low* - way lower than your SL's. I ripped them out it just looked wrong. I'm suspect of King Springs and their quality control. I had the right part number, but they were obviously a different size. They were from ebay for what its worth - they may have been factory seconds, who knows?
If it doesn't fit, use a BIGGER hammer |
29-12-2015, 06:35 PM | #18 | |||
AU DIE HARD
Got Kings SLs all round on mine, Sat ok but lost some ride feel so have put the stock XR 8 ones back on the rear , ( still got the SLs in the shed if any one is interested Cheap lol )
29-12-2015, 08:29 PM | #19 | ||
Narooma represent!
01-01-2016, 11:20 AM | #20 | ||
Mine's on SL in the rear as well, way too high:
01-01-2016, 03:40 PM | #22 | ||
FG XR50 TURBO
01-01-2016, 05:54 PM | #23 | ||
3..2..1..
Kings will always sag a lot,,they're just not a great quality Spring.
They're popular because they're cheap, and have a vast range. |
