02-09-2014, 06:30 PM | #1 | ||
hi all I have a few engines that I really want to store for an extended period of time . what is the best way to do this .do I need to flush the water out of the block as it has coolant in it and do I fill it full of oil
02-09-2014, 06:49 PM | #2 | ||
Brad
I think you can spray something in the bores as the piston rings can "stick" had this happen to a few diesel motors we have fitted fro wreckers had low compression because of this but were fine when "unstuck".
Silhouette BF MKII F6 Plazmaman Intercooler Kit, ID1000, 34mm Internal Wastegate and Turbosmart Actuator, Tein Coilovers, Focal Audio, XXR 521 18x8.5 18x10 |
02-09-2014, 07:00 PM | #3 | ||
Hoon On The Rise
Run it on some two stroke mix, pour a little down spark plugs etc.
Keeps it lubricated. Change oil and new plugs before using again...
Stomp 'n' Steer FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
02-09-2014, 07:32 PM | #5 | ||
I wouldn't flush the coolant as it has a corrosion inhibitor in it. Might be worth getting some VCI paper to wrap it in too.
02-09-2014, 07:35 PM | #6 | ||
Engine oil is not a good anti-rust product on surfaces exposed to air.
Drain coolant. Fill engine with oil, quarter fill cylinders with a thin oil Rp7 or WD40, rotate once & quarter foil again. Install plugs, seal all openings, pack away.
The true danger only occurs when you take a potentially dangerous piece of machinery and place it in the hands of the most unpredictable species on the planet. Human behaviour, as history has catalogued, cannot account for what any persons actions may be, especially concerning their love of the motor vehicle. http://www.fireservicecollege.ac.uk |
02-09-2014, 08:54 PM | #7 | ||
Thailand Specials
My engine has been sitting outside in the elements with no plugs or injectors, no doubt it would have been rusted up inside.
We're going to pull it down anyway, if its rusted up is it just a matter of honing it again? |
02-09-2014, 11:16 PM | #8 | ||
Experienced Member
If I'm going to store engines for long term I usually pull them down & store in a dry place reason being when engine is going to be used again 9 times out of 10 you will have to replace seals & gaskets that usually harden up/perish over length of time
02-09-2014, 11:56 PM | #9 | ||
if i was going to keep it in storage for 10 or 20 years id buy a **** load of cheapest nastiest engine oil i could find and fill it to the top till its running out the tappet cover then put the cap on,
as for leaving coolant in the engine...... im not sure how i feel about leaving it with coolant in it for a long long period, i would be worried the chemicals would eventually separate leaving areas exposed to plain water, if i was going leave it with coolant in it, i was going to say the longest life stuff, but thinking about it some of that waterless coolant/corrosion inhibitor might be the go ?? |
03-09-2014, 12:04 AM | #10 | ||
you might getaway with a hone, all you can do is give it a whirl, but the lesser metal you take off the better.
03-09-2014, 12:11 AM | #11 | ||
Thailand Specials
Its going to be pulled down, new pistons, rings, bearings etc, long has 113,000km on it, should be able to use standard sized stuff I'm assuming so no need for machining?
03-09-2014, 11:17 AM | #12 | ||
That's not many ks , i might sound like a tight wad, but if turns out it only needs a a light hone I would probably have a go at reuseing the old pistons if they are serviceable unless you really want to change them .......unless it's going to be a hotrod or something ? Up to you Damo, see what it takes to tidy the bores up.
03-09-2014, 04:32 PM | #13 | ||
BANNED
I have a V6 that I just stored.
loosened the head bolts , removed timing belt so all valves closed , tightened head bolts very lightly so compression could eek out as I plan to turn it one rev per year by hand....also ...this stopped air getting into chambers via inevitable open valve. squirted a bit of light machine oil down spark plug. that's it....once a year or so spin it by harmonic balancer bolt and socket. |
03-09-2014, 04:36 PM | #14 | |||
Thailand Specials
Seems slow to rev out as well. I've got a standard rebuild kit here in the garage which is the main reason why I'm going to pull the wrecker engine down (the one with 113,000km) and reco it, got the parts here so why not? I'll chuck my head on it as I've got a CMS Stage 3 head. |
