Old 24-01-2015, 09:02 PM   #1
pete05
pete05's Avatar
Default Rear bumper and side skirt removal
Hi
Whats involved in removing a rebel rear bumper and side skirts without damage?
Thanks
Pete
AU11 xr8 manual
pete05 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2015, 10:16 PM   #2
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Cool Re: Rear bumper and side skirt removal
Bumper is not to hard but side skirts are glued (so I believe)
Bumper has 3 (or 4) bolts you can access on both sides underneath. Don't forget the tie under the middle; again I think this is held on by rivets which you will have to drill out.
UK
Old 25-01-2015, 11:11 AM   #3
david lee
Default Re: Rear bumper and side skirt removal
there are 2 bar bolts inside the boot behind the quarter panel trims near the tail lights and 2 behind the plastic splash trays you have to take the 3 plastic clips off on either side to access those 2 bolts instead of drilling the 2 rivets underneath you can use a angle grinder and replace them with 2 small nuts and bolts not sure about skirts but why do you want to take them off
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2015, 11:14 AM   #4
pete05
pete05's Avatar
I have bought a rebel bar and side skirts from a wreck and need to remove them.
AU11 xr8 manual
Old 25-01-2015, 12:56 PM   #5
mcfly94
mcfly94's Avatar
Side skirts are clipped on bottom, and held by rubber seal on top, rubber seal has clips which hold both in together, be careful, use something the thickness of a butter knife, the clips break easy and so do the skirts
Current Car: 2002 AUII LTD
408ci Windsor, T6 S488, TH400, 2 Piece Shaft, Helicial LSD 3.23 IRS
Daily: 1998 Mitsubishi Super VR-4 Legnum
mcfly94 is offline   Reply With Quote Multi-Quote with this Post
