15-08-2015, 03:55 PM | #1 | ||
can the heater switches be removed by just removing the radio suround panel as that panel clips in to the big oval dash suround thanks
15-08-2015, 04:35 PM | #2 | ||
Hi. You need to remove radio to expose 2 screws holding the big oval panel in place. After the screws are out the panel clips in place. Cheers MD
HI I'M MICHAEL 2003 ACID RUSH BA FUTURA WAGON light up window switches | auto on cruise control | doubleclick window lift from remote |
15-08-2015, 05:47 PM | #3 | ||
16-08-2015, 03:40 PM | #4 | ||
The radio comes out first, then the heater controls. Then the oval facia.
2015 MK7 VW GOLF GTI __________________
Previous Cars 2002 AUIII XR6 1995 EF Falcon XR6 2003 LR Focus Zetec 1989 KE Laser TX3 |
16-08-2015, 06:29 PM | #5 | ||
Hi. If its a factory radio the front of the radio is fixed to the rest of the unit. If it is an aftermarket radio it will be mounted in a sleeve that will stop access to the screws. Either way the radio will need to be removed. Cheers MD
16-08-2015, 08:18 PM | #6 | ||
Spanner Thrower
i know series 1 AU's have 4 screws holding the tear drop, pretty sure S2/3 would be the same. but heater controls on the S1 i know are held to the teardrop with 5 screws, not sure with S2/3.
1999 AU Futura Wagon (Nickname Betsie the Barge-***) Current Mods: Fairmont Cluster, LED's Changed to Purple, Lukey Competition Extractors, 2.5" Hi flow Cat, Hi-Stall Converter, ED Box with FG internals, AUIII VCT Fuel Rail + Injectors, F6 Fuel Regulator, Stereo upgrade, Aftermarket LPG. Awaiting Wife Approval Mods: TE50 Front Bar, AU Tickford/SR Interior, Roof Racks, Slimline Weathershields, 2.5" Cat Back Exhaust, 27mm Front Sway Bar, Other Shiny things! |
16-08-2015, 11:25 PM | #7 | ||
yes there are 4 screws that hold the heater switches to the oval surround which tells me the the whole oval panel must be uncliped to get to the screws
