Old 30-09-2015, 03:25 PM   #1
12slots4ever
12slots4ever's Avatar
Default Rear wheel hub will just not come off
hi everyone. My 2000 model AU XR8 has a crook rear wheel bearing which my son & I are doing at home. Everything pulled down without a problem until it was time to pulley the hub off. It just won't move & we have no idea on how to get it off. We have pullers and are using them to no avail. Please help us if you can,I'm stuck with no car!! George
12slots4ever is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2015, 07:38 PM   #2
mik
mik's Avatar
Default Re: Rear wheel hub will just not come off
How did you go George ? I haven't touched mine for some years, but from memory mine where pretty stubborn to get off also,
I think a bit of rust around the centre hub was the issue with mine, a bit of CRC or wd40 to loosen it up and a puller and some blows with the big hammer to help jar it loose did the job, don't forget to release the handbrake.
Old 02-10-2015, 07:42 PM   #3
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
I could only remove mine after soaking it overnight with Inox and a BIG 3 claw puller...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2015, 11:54 AM   #4
FTe342
FTe342's Avatar
An excellent product for dissolving rust is Rost-off made by Wurth. I think Repco sell it. 10 times faster than wd40 or crc
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2015, 12:20 PM   #5
mik
mik's Avatar
Cool , thanks for the tip , i`ll give it a try ;) .
Old 05-10-2015, 04:32 PM   #6
mif73
CNC fixer guy
mif73's Avatar
Rost-off etc is great, can also try a paint strip gun to expand the hub while pulling, can also squirt some freeze spray on the splined shaft to shrink it, again while under puller tension.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player.
Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers.
mif73 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2015, 02:05 AM   #7
12slots4ever
Thanks everyone, jobs done! I ended up taking the whole hub assembly to the local steering guy & he pressed out with the old and in with the new bearing and charged me $66. To do the job cost me a total of $165, any idea on what the cost would be for a mechanic workshop would charge???? George
Old 06-10-2015, 08:06 AM   #8
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Yep, i paid $200 two weeks ago - I don't have a 60 ton press, so i was happy to let the local mechanic do the job!
cheer's, Maka
Old 06-10-2015, 09:25 AM   #9
12slots4ever
Was that doing the job yourself and $200 in parts & press labour or $200 + parts finished!
Old 06-10-2015, 09:34 AM   #10
Maka
Maka's Avatar
Sorry George, that was with parts supplied by me. I paid $140 for a pair of bearings sourced locally. All up $340, they did all the labour, i'm happy with what they did.
You did good!
cheer's, Maka
Old 06-10-2015, 09:38 AM   #11
12slots4ever
I suppose you dont save much these days doing it yourself, I've always told my sons that you have to fix some things yourself!!! Thanks George
Old 06-10-2015, 10:06 AM   #12
mif73
CNC fixer guy
mif73's Avatar
Well done.
I thought you were stuck trying to pull the hub off the spline of the half shaft, obviously you already had that off, yeah you need a decent press to separate bearing and hub.
PS: Too late now, but make sure there are no scores or marks on the hub as the OD of the hub sets the preload on the ID of the bearing.
If scored, the new bearing will be loose/fail in no time.
Cheers.
Old 06-10-2015, 05:51 PM   #13
Phildo
Phildo's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Excellent work on the BF Brake information. Technical Contributor: For members who share their technical expertise. - Issue reason: Photo Essay - Centre Console Disassembly
This.
Always keep a can Wurth Rost Off Plus in the shed.
If you ever see a good price on a hydraulic gear puller on Gumtree, etc, then buy it straight away. Useful gadget. Weighs a ton, though.
Click here for my previous Photo Essays and Build Threads.
Good people. Bad people. Smart people. Dumb people. Car crashes. Vomit.
Read about it all at Cabloid, the web site that has stories and photos about my life driving a taxi at night.
www.cabloid.com.au
Phildo is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2015, 11:55 AM   #14
XRMick
Good pics Phildo, serious looking puller there. Doesn't look like there would be much that could resist that!
XRMick is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2016, 05:11 AM   #15
xxx000
What do you use for front rotors where you have a bearing cap instead of the solid centre like on the rear?
xxx000 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2016, 11:46 PM   #16
XR8235
Take the cap off
XR8235 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2016, 09:10 PM   #17
ronwest
All Bran = Regular Member
http://www.fordforums.com.au/vbporta...?articleid=222
