Old 28-06-2017, 08:31 AM   #1
RACERED
Winding roads please
RACERED's Avatar
Default Very slow coolent loss--FOCUS ST--
Hi guys.. 2013 ST. Has very slow coolent leak.
Always runs normal.. never has a temp rise.. sometime interior smell a little... Could it be a heater hose? Loose radiator hose clamp? Anyone ever hear of an ST with issues..... Mines 4yrs old.. not thrashed and only has 58000km
HURRY UP WEEKEND DRIVE
RACERED is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2017, 01:09 PM   #2
DZFord
DZFord's Avatar
Default Re: Very slow coolent loss--FOCUS ST--
Interior smell - I'd be thinking the heater core.
The best way to tell is to use a cooling system pressure tester - see if it holds pressure - and if it doesn't - find the leak
Small hand pump versions are available
Old 29-06-2017, 09:01 PM   #3
falconhell74
falconhell74's Avatar
Ditto pressure test the cooling system , if the pressure drops you will have to find the leak, if you can't find a drip check the passenger side carpet to see if it is damp , if not you may have a very slight head issue, leaking internally
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 29-06-2017, 09:18 PM   #4
RACERED
RACERED's Avatar
Slight wet engine cover below engine so slight drip from somewhere.. will have a look around for a drip..may be a pin ***** leak in hose or loose clamp
