Old 04-02-2018, 12:54 PM   #1
wasim
Default xr8 ute battery goes flat after 2 weeks of just sitting?
Battery is brand new and if the car sits idle for 2-3 weeks the battery is flat - any clues?
Regards, Wasim
wasim is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2018, 01:04 PM   #2
raceteam
Default Re: xr8 ute battery goes flat after 2 weeks of just sitting?
Glove box light?
raceteam is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2018, 01:24 PM   #3
snap0964
Are the doors closed but left unlocked ?
snap0964 is offline   Reply With Quote Multi-Quote with this Post
Old 04-02-2018, 02:55 PM   #4
wasim
Doors are locked and the glove box isn't on nor is anything else?
Just as a hunch it wouldn't be anything to do with starter motor - it's turning over slowly and I have a replacement to go in.
Thanks for the quick replies.
Regards, Wasim
Old 05-02-2018, 12:50 PM   #5
snap0964
Well I suppose you can disconnect the Batt +ve, hook a meter on the lead and the +ve post and measure the current flow with the car locked. The tech section has the fuse cct feeds - start pulling fuses and see which accessory section the current draw is coming from.
Be aware the door actuators still draw power with doors closed but unlocked, so take this into account.
This is assuming too you've looked at anything added to the car non factory that might draw batt power.
Old 05-02-2018, 01:10 PM   #6
Probably a shorted diode in the alternator; does battery warninbg light on the dash go on as it should with engine off ignition on? If not, suspect a shorted alternator diode.
aussiblue is online now   Reply With Quote Multi-Quote with this Post
Old 05-02-2018, 02:51 PM   #7
snap0964
That is a good point.
You can set up the meter as described, and disconnect the alternator + lead and see if the current drop disappears - be careful not to short it to anything.
Old 05-02-2018, 02:57 PM   #8
TICKFORD220
2009 xr turbo,2004 fiesta
Get a c tek trickle charger if your car is sitting for that long without being started or driven.
As also said check with a multi meter if the battery is actually charging.
Have you checked battery voltage before trying to start it or while trying to start it?
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2018, 08:04 PM   #9
wasim
Thanks for all the suggestions on what to look at - I'll check these out over the weekend.
Thanks, Wasim
Old 05-02-2018, 08:17 PM   #10
Did you buy the Ute new?
If not did the previous owner fit any electrical accessories or upgrade the audio system with an extra amplifier?
If there are no parasitic electrical loads draining the battery, maybe the new battery you got was not as new as you thought it was.
Sometimes batteries can sit in stock for long periods in small turnover outlets.
I would suggest getting one of these chargers to maintain and recondition your battery.
It will automatically analyse it's condition and select the right conditioning or charging cycle.....
https://www.fordforums.com.au/showpo...&postcount=400
Old 06-02-2018, 08:34 AM   #11
Electrolyte Burns
Or just put a 5W solar panel on it.
Electrolyte Burns is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2018, 12:37 PM   #12
speedzter
Dont forget to check the charging voltage when running.
speedzter is offline   Reply With Quote Multi-Quote with this Post
