Where is the PCV valve located on the VCT Au engine? The engine is burning oil and it's only done 250,000km. I want to check to see if the valve is blocked.
Thx. |
Next upgraded Mk1 Leopard
![]() Join Date: Jan 2005
On the top of the engine cover at the front, connects to the intake
UK
Au Falcon = Mr Reliable
Hi sednwol, its plugged in to a grommet next to the oil filler hole on your rocker cover, a rubber hose is connected to it & its either made out of metal or black plastic.
Edit - I didn't see ya there UK, you too quick lol. cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792 Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007) Last edited by Maka; 07-03-2018 at 07:54 PM. |
