Old 17-03-2018, 05:06 PM   #1
Vortex-98
Vortex-98's Avatar
Default What cars have 3.7 diff gears
Hey I'm looking to upgrade my diff gears in the AU,thinking 3.7s or 3.9s would be ok..do ba xr6 have 3.7 or xr6 turbo....
[B]WTB (Syd)...AU 5.0 or xr8 4 speed auto transmission in good working cond /B]
Vortex-98 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2018, 05:16 PM   #2
Jack91
Jack91's Avatar
Default Re: What cars have 3.7 diff gears
No. 3.45. M78 diff is shared in heaps of commodores and others. Skylines and pintaras are the most common donors for 3.9 and 3.7. They're a bit hard to get now be cause everyone wants them, new gears can be had for $400 all the way up to 4.11. I found a shop in Melbourne to supply and install for $1000
Jack91 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2018, 06:10 PM   #3
au350hp
Do the maths first so you know what RPM will be at 100km/h.
au350hp is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 02:38 AM   #4
josh1990
You'll find 3.73 gears behind 6 speed manual falcons. However, Turbo and V8 models are M86 and will not fit your housing. As mentioned, you can find the ratios you're after in old pintaras and skylines. But be warned, there are 3.89 and 3.91 ratio from those models. You want the 3.91 as the 3.89 are notorious for whining. I used the 3.89 in my BA and they whined like a banshee. To the point I went back to a 3.45 (I do miss the acceleration though).
2017 Ranger XLT 3.2L Hi-rider
josh1990 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 03:05 PM   #5
TICKFORD220
2009 xr turbo,2004 fiesta
I got a brand new genuine dana set of 3.9 for my au xr8 for about $500 on ebay,only use genuine dana/spicer gears.
I haven't fitted them yet though $$$$$$
TICKFORD220 is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 05:16 PM   #6
Nu66et
Only the M86 cars use 3.73 diff gears with the 2.9/2.6 first gear ratio. Standard boxes have the shorter 3.3 first gear so only got the 3.45 diff ratio
Nu66et is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2018, 09:57 PM   #7
Vortex-98
Vortex-98's Avatar
Thanks for the info ...so with the skyline diff is that from the regular 32.33 gts gtr type or the boxy shape earlier one the 31 and what model fords got the 6 speed manual...are these lsd centres
Old 22-03-2018, 12:15 AM   #8
NCII40
XR6T BA 2002
NCII40's Avatar
0431557226
Call Glen
He built my diff, he used a VL turbo LSD 4 pinion and 389s from a skyline
I have no Whine in my diff at all
based in Keysborough.
(GJV Automotive)
He has a ebay store too, His username is Vicmelboz.
He specialises in BW diffs
You then need a speedo corrector behind the cluster
If you have an auto then need to follow some instructions i posted on how to get the VSS to talk to the ECU to shift the trans properly
https://www.fordforums.com.au/showthread.php?t=11464112
XR6T 2002 BA
NCII40 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2018, 06:35 PM   #9
josh1990
Correct, can't edit posts after you reread them later though
Supposed to read "You'll find 3.73 gears behind 6 speed manual Turbo and V8 models, however the diffs in these are M86 and will not fit your housing."
The longer first gear with 3.45 gears is a hoot rolling around town though
Old 22-03-2018, 09:27 PM   #10
Nu66et
Yeh im running a turbo box with 3.23's
Old 06-05-2018, 04:00 PM   #11
Interceptor
HSV - I just ate one!
Interceptor's Avatar
fwiw, my BF series 1 XR8 6 speed manual had a 3.45 diff
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is offline   Reply With Quote Multi-Quote with this Post
Old 06-05-2018, 06:06 PM   #12
Vortex-98
Vortex-98's Avatar
Is changing just the centres to a higher ratio easily doable....like find a xr6 turbo grab the diff centre ,bolt her in an go do sum hectic donuts an burnouts...
Old 12-05-2018, 01:53 AM   #13
BOTTLEDUP
No. AU & BA onwards are completely different diffs and not interchangeable.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
