Old 11-08-2018, 11:49 AM   #1
Hypnotherapy1
Default Central locking
My AU Falcon has a problem with door locks. When I lock the doors I can hear each door lock but just as quickly they unlock even while I am holding the key in the lock position. Does anyone have an idea what the problem could be.
Hypnotherapy1 is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2018, 01:09 PM   #2
gassa
Default Re: Central locking
Au falcons had issue with moisture in the lock mechanism
gassa
gassa is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2018, 04:31 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
If it stays open you have a broken actuator in one of the doors.
UK
