Old 20-10-2018, 09:57 PM   #1
zillah
Default Repair broken plastic for car tail light
Dear Experts
There are so many glue out there and I am confused to which on to choose to repair this tail light for Nissan Sentra
https://imgur.com/a/wUcUXF3
Can you please share your experience and any trick I need to be aware when I do repair
Thanks
zillah is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2018, 09:15 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: Repair broken plastic for car tail light
Any of the two part epoxy glues should be fine.
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2018, 09:19 AM   #3
zillah
Noted
This for example ?
https://www.bunnings.com.au/selleys-...esive_p1230054
Thx
Old 21-10-2018, 09:52 AM   #4
uniacidz
uniacidz's Avatar
Repco sell glue as well. 30% off this weekend for roadside members sale on store items
Sent from Samsung S7 Edge [Oreo]
Before -
ED Falcon Futura (sold)
EL XR6 (R.I.P.)
VX SS (R.I.P)
VE Berlina
uniacidz is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2018, 10:12 AM   #5
zillah
Thx for let me know
Old 21-10-2018, 10:22 AM   #6
Fed
I've found plastic welding with an old soldering iron better than glue, you can get the right filler sticks the the particular type of plastic from Bunnings.
I found all the info I needed right here in the BA manual in tech resources along with a bit of google & youtube.
https://www.google.com.au/search?q=p...w=1097&bih=547
Fed is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2018, 10:34 AM   #7
zillah
Can you please share more info ,,,which one is that ?
Regards
Old 21-10-2018, 11:56 AM   #8
Fed
I'm not sure what your question is zillah, which one is what?
https://www.youtube.com/results?sear...soldering+iron
The type of plastic you have should be cast into the part somewhere, you need to know it so you buy the right welding sticks. After that it's like icing a cake.
Old 21-10-2018, 12:43 PM   #9
wodahs
wodahs's Avatar
ive even seen old time pro's use pieces of another (the same type) plastic lenses so it is the same material and matches better when repairing older units depends on how fussy you are I suppose
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2018, 01:51 PM   #10
zillah
I thought a plastic soldering iron is different from a soldering iron that we use it for soldering electronic circuit board.
From the YouTube link that you posted now clear to me
