Old 22-11-2024, 10:34 AM   #1
edwardbear
Default BA Falcon Instrument Cluster on AU Wiring Harness
Hi all. Just wondering how I can adapt a BA instrunet cluster to my AU wiring harness. Is it possible to drive the instruments without the CAN bus setup from the BA?
edwardbear is offline   Reply With Quote Multi-Quote with this Post
Old 22-11-2024, 11:04 AM   #2
Interceptor
HSV - I just ate one!
Interceptor's Avatar
Default Re: BA Falcon Instrument Cluster on AU Wiring Harness
depends on how keen you are to come up with the electrical componentry to make it all work.... it wont be easy
I dont care if some prius driving eco-hippy thinks its politically incorrect for me to drive a V8..... I'm paying for the fuel!
Interceptor is online now   Reply With Quote Multi-Quote with this Post
Old 22-11-2024, 01:07 PM   #3
edwardbear
I happy to have a go but no idea where to start realy. I have found some wiring information here but the can bus in the BA doesnt appear to exist in the AU.
Old 22-11-2024, 11:39 PM   #4
Interceptor
Exactly. You'll need to find some way to recreate the CANBUS signals to the BA cluster.
Why the interest in putting a BA cluster in an AU?
Old 23-11-2024, 09:25 AM   #5
edwardbear
I have an old car that I have fitted the AU V8 running gear in as well as the wiring harness however the AU insrtrument cluster is too long for the original opening in the old cars dash panel. I have a BA cluster that is shorter and will fit so the reason for wanting to adapt the wiring. I am starting to think maybe change to BA wiring and throw the AU stuff out but then I have a V8 manual from the AU donor car and I guess I would be needing a V8 manual harness from a BA?
Old 23-11-2024, 09:43 AM   #6
Interceptor
Best just to use whatever harness you've got to run the engine and do something with aftermarket gauges
Old 23-11-2024, 05:55 PM   #7
edwardbear
Yep I think I will give the BA cluster a miss and chop the dash to fit the AU instead thanks for your input
