To suit 3/8” hose, and the threaded end is M16x1,5 to fit Falcon radiators.
I just want to buy one. :-/ Not a kit. |
Unfortunately no self serve yards here anymore, and I’d need to form a sealing bead on the tip - can’t weld to save myself - so that would be TIG work to a third party.
If I didn’t have a retaining bead on the hard line, it would be a cause of worry - whether the risk was real or imaginary. It’s only necessary to get such a fitting because I refuse to bypass the radiator tank cooling loop, this ideology is prone to causing arguments on AFF. ![]() |
Regular...with metamusal
![]() Join Date: Oct 2009
4 users like this post: |
#5 | |||
The ones I’ve bypassed, I didn’t bother to flare the hard line and had no dramas. ZF6 with an FG V8 and several AU/BA. |
The tube beading and bubble flaring tools I’ve seen and used, wouldn’t hold a candle to factory steel hardlines. Even adding extra bends takes a lot of care/patience to avoid collapse and kinking.
#7 | |||
Incidentally, Sparesbollocks customer service have just advised me the PWO6115 is now made to order only.
![]() *…nother |
![]() Join Date: Oct 2006
Try your local Speedflow distributor. https://speedflow.com.au/adapters/metric/ and https://speedflow.com.au/distributors/
regards Blue |
Neither Speedflow nor Aeroflot have the correct fittings, it’s a bit frustrating as I’m trying to coordinate a single time to install and commission.
The AU looks to have a different, slightly smaller, threaded end on its hard lines - an imperial inverted flare - is this correct? |
I'd still try your speed flow distributor I know mine at least, Lost Cause Racing (yes; they also have a sense f humour) , also stock fitting from many other brands including Brown and Miller Racing solutions per https://bmrs.net/flipbook/?page=10 and have always been able to find what I have needed.
regards Blue |
Go to Rocket industries or similar and get the correct threaded fitting with a compression sleeve on it. Flare not needed then. But common sense is bypass the radiator to stop milkshake risk.
#12 | ||
