Old 27-06-2005, 12:03 PM   #1
SILVAGHIA
Default AUII 5litre V8 knock sound in motor
Has anyone exprerienced a knocking sound in the 5 litre V8. It occurs when idling and after the motor has warmed up. It sounds like a big end type of knock. It has done 90 thousand. It disappears just off idle and the motor is quiet as a mouse when cold. I've been told it is common and is the timing gear. Temp. and Oil pressure is excellent. Any ideas?
SILVAGHIA is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2005, 06:15 PM   #2
xceler8shun
Ford Fanatic
xceler8shun's Avatar
I get that sound coming from around the airbox everynow and then like something is knocking..
lately everytime i start the motor from cold for 1-2 sec i get some wierd noise under the hood from somewhere like someone is strangling a rooster. probably just a loose belt
xceler8shun is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2005, 06:46 PM   #3
Hoops
I'm Back
Hoops's Avatar
Get your starter motor checked, i had the same problem and thats what it turned out to be :
Dont go through Ford they will try and charge you around the $1200, ended up getting mine done for $350, go's to show it pays to shop around
Hoops is offline   Reply With Quote Multi-Quote with this Post
