Old 19-07-2005, 10:10 PM   #1
mockgt
Default 400rpm
ok so i got a new cluster with a tacho in it the other week and have been obsessed with it ever since. taking notice of what rpm at what speed and so on, should it be on 400rpm while ideling in gear and 600rpm in park and neutral?? seems a bit low to me
Old 19-07-2005, 10:22 PM   #2
Kryton
Kryton's Avatar
yes it is a bit low.
sometimes i can get the van to idle down to less than 100rpm even though its clearly idling at normal speed.
check your idle speed with another source.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 19-07-2005, 10:52 PM   #3
John_LS1
the first line on the tacho is 500 rpm so im assuming its above this?
Old 19-07-2005, 10:53 PM   #4
mcflux
mcflux's Avatar
v8 tacho?
Old 19-07-2005, 11:50 PM   #5
John_LS1
his car is I6 and the cluster is from I6.
Old 20-07-2005, 11:02 PM   #6
mockgt
yeh I6. i dont think it really matters as the car has never cut out and it doesnt really sound sick to me. was just wondering if it was normal
Old 21-07-2005, 07:42 PM   #7
BuuBox
My EB seems to idle around the 400rpm mark in gear. Strange, but like you, I've never had any issues with a rough idle, or it cutting or spluttering out.
BuuBox is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2005, 03:13 PM   #8
EDXR8
EDXR8's Avatar
You sure because as John_xr6 said, the first line on the tacho is 500rpm, so if you are idling at 400 is isn't even registering.
EDXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2005, 05:42 PM   #9
mockgt
yes on closer inspection i see that it is actually 700rpm. dont i feel like a dick. again
