the pom
I was trying to find out why the rear speakers were crackling (simple answer - they're fooked) when I noticed there seems to be a space for an 8 or 10 inch sub in the middle of the parcel shelf?
Which cars came with the sub (if that's what it is), and is anyone here using that mounting for theirs? I had planned on cutting 8s into the shelf, but now it seems I wont have to? |
Premium sound got the sub, at least it did on EF/EL.
To be honest i havent even checked mine.
Was it an option to have the space for a sub or was it standard on some models? Intresting...
Me fail English? That's unpossible.
Low and Loud
yep thats a sub hole.
EB2/ED Ghia's Fairlanes and LTD's had the factory 8" Sub in the back. Wasnt bad for the time but sound pretty tame these days. Most people removed them and used 12" subs in a box. As rob said, Premium Sound got the Sub. Also got a amp aswell, (50w x 4 Alpine i belive)
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() Last edited by InitialD; 20-01-2005 at 11:35 PM. |
#5 | |||
i ripped it out they are crap!!! |
the pom
Thanks all. I'm not after a competition or high SPL setup, just enough to sound good in the car, so I reckon a decent 8" sub with a pair of 6" coaxials in the back running off a small 3ch amp plus components up front off the head unit (45w/ch) will do nicely.
Will have to see what proceeds I make from my old van - currently bidding at 530 bucks |
likes falcon's
it wouldnt be to bad trying a 10" in there save bita space u know and still bita bass
![]() mercs on the other hand (big s classes) put dual 6" on each side 4x6" in parcel shelfs NOW THAT is a nice sound ;)
www.carhubsales.com.au |
likes falcon's
3channel amp? youd be best going a 4channel run 2 channels to the subs
Bass and an 8 inch sub is barely exsistant, turn it up and its distortion city, well this is going by the factory setup, maybe if you run an aftermarket 8 inch (i think audiobahn have one) and a better amp may suffice.
the pom
There's only going to be one sub, and if I'm completely honest, I'm not going to turn it up any louder than you'd get out of an average head unit. Just want it to sound good at low volume.
Low and Loud
Good Quality 8" Subs are hard to find. Friend tried to get one for his EL for about 2mths looking in stores. Gave up and went 10" in box
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
#12 | |||
ooga-lagga-ligga-lagga
jaycar i sell a pretty good one, 100watts rms $40, huge! magnet. pump 100w or more into it and it should crank. you would most likley need to stiffen the mounting though but would pump out the kinda bass ur lookin for or more.
#14 | ||
Formally ED I6
Dont bother, I put one in my ED fairmont 3 years ago and turned up with any more bass than my 6" pioneers give out it rattles the crap out of the parcel shelf, the back window, and most annoying the rear centre seat belt retractor (But EBs dont have the centre seat belt retractor), if you still want to try it you will need a free air sub.
The speaker is now just sitting there not hooked up (to cover the gap i cut out) and i now run a boxed 12" (No rattles). Just spend the extra and get a boxed 10" or 12" (should only cost about $100 more, inc. box)
Daily driver 98' AU 349ci Fairmont Ghia on LPG --------------------------- Other 93' ED 5spd 4.0L NA Fairmont 13.75 @ 101mph |
#15 | |||
yeh stiffening of the parcel shelf is highly recomended even with 6x9's,6.5.etc |
#16 | ||
Number 5 is alive!
Yeah i put a ten inch in the shelf of my ED, As long as you put a Free air sub in you shouldnt have any sound issues.
The hole is for an 8", but my tin snips and a piece of 16mm MDF did the job nicely.
Kerry Tickford wings are for Tickford cars! "Experimental Racer" #6 1994 Gunmetal XG XR6 1997-1999 [B][COLOR=Red] 1994 Le Mans Red ED 2008 MA XR5 Mondeo 2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced ![]() |
#17 | ||
Just a thread I was about to post. Man I love you ff.au!!!
Anyone know a brand that makes a decent 8" free air sub?
93 ED Futura, I6, KKK500r Turbo, Dev 5 head, custom Surecam, TKO500, Lokka. 250rwkw@4000rpm, 9psi, and lots of boost taper. Comming soon: T04Z, plenum, TrueTrac. |
#18 | ||
I got an 8 inch sub from 1lowea (ff nickname) for pretty cheap. It was 'audiopipe' some us brand I'd never heard before its free air and works pretty well. Keep the grill bit on the factory one if you put a replacement in as the carpety bit will hit the sub and give you all sorts of crappy sounds.
www.cpaudio.com
#19 | ||
Also EB1 also has the place for the sub its just not cut out, just a big round indent
#20 | ||
Number 5 is alive!
Pioneer is one of the only manufacturers that make free airs.
#21 | |||
#22 | |||
Boss 290 BA GT Goodness
I had an 8" in my EBII Fairmont Ghia, as it came with premium sound package. I replaced it with a 550w Pioneer 10" item, but had to hack the crap out of the parcel shelf, as the workspace is to tight to use the grinder.
Member of the FPV & XR Owners Club of ACT Web Links To Check Out Shannons Club Garage Facebook Photo Albums |
#23 | |||
Formally ED I6
#24 | |||
E-Series Owners Club
#25 | ||
#26 | ||
^^^ Makes a bit more sense, a recording company came up and I was going wtf? Cheers mort.
93 ED Futura, I6, KKK500r Turbo, Dev 5 head, custom Surecam, TKO500, Lokka. 250rwkw@4000rpm, 9psi, and lots of boost taper. Comming soon: T04Z, plenum, TrueTrac. Last edited by donno; 22-01-2005 at 07:48 PM. Reason: spullin |
#27 | |||
#28 | ||
need more boost
Total Recoil (www.totalrecoil.com.au) do speaker repairs, and have done for many years on high quality speakers. They've got their own speaker range now too though, and i would think the stuff to be very good, i think they got around 140dB out of two 6X9's in an SPL comp a while back. Oh, my point is LOL, they make an 8" free-air sub that may be worth looking into.
Jared
'94 ED Falcon GLi Suspended by: kings, koni, pedders Rolls on: 17" AJR Director's Stops due to: bendix, DBA Shifter connected to: T5 manual Power from: ??? Interior: velour and woodgrain Cost: stuff all :P |
#29 | |||
windsor user
strange that steves has the hole........ his car hasnt been re-shelled at some stage has it??? |
#30 | |||
