14-08-2005, 01:57 PM | #1 | ||
BUILT FORD TUFF
Did a run today for about 100km on the highway and was pleased with fuel economy, 9.8L per 100km on Hway at 105km/hr and average about 15.9 around town, so it goes to show you dont have to use alot of fuel just because you have a fast car
2015 FGX XR6 Turbo |
14-08-2005, 02:03 PM | #2 | ||
likes falcon's
sounds better than stok ea 3speeds lol
www.carhubsales.com.au |
14-08-2005, 02:49 PM | #3 | ||
windsor user
sounds like great economy....
mines around 8-10l/100 on the highway. wish it had 400+ kw though!! |
14-08-2005, 02:50 PM | #4 | ||
Great economy mate!
Unfortunately - the same rule doesn't apply to the 8's :P
1998 Ford Fairlane - 4.0L
18x8 RJR rims - Tinted - King Suspension - 2.5" D&T Cat Back Exhaust |
14-08-2005, 03:16 PM | #5 | ||
thats Great economy mate
14-08-2005, 10:26 PM | #6 | ||
that's awesome. hows it go when you put the boot in though?
14-08-2005, 11:26 PM | #7 | ||
Last warning
amazing what a good tune does ;)
if you're not using the power, theres no reason why it'd chew it all!
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer |
15-08-2005, 01:18 AM | #8 | ||
Former E-Series Member
Very good to know. Someone was saying that even if an engine is revving a bit high on the highway, it isn't actually on boost unless you give it a bootful.
15-08-2005, 01:29 PM | #9 | |||
how do you get such good fuel economy?? what did you do or use =D |
15-08-2005, 01:32 PM | #10 | ||
Last warning
with an aftermarket computer, you can tune the air fuel ratio's to be spot on what they should be.
if you look at a stock cars air fuel ratio's, they're by no means optimal. by adjusting them with an aftermarket computer you're going to get better fuel economy and a better fuel burn, thus more power. if a car has 400rwkw, it doens't mean its using all that power all of the time. it takes just as much power to shift a 1.5 tonne object no matter how much power the actual engine makes. but by optimising what the engine does with its supplied fuel, air and spark, you can get better then stock fuel economy. its all in the tune.
15-08-2005, 01:33 PM | #11 | |||
Official AFF conservative
A cup half empty... but full of euphoria. |
15-08-2005, 01:50 PM | #12 | ||
Custom user title
But even with no bov on cruise it wont boost, as the engine isnt flowing enuf air to spool the turbo up.. The bov has nothing to do with it.
On a supercharged car it may be differnt. |
15-08-2005, 11:02 PM | #13 | |||
spot on, bov doesn't play any part in the engine making boost. it only releases the pressure in the manifold/intercooler when you back off the throttle suddenly so the pressure isn't forced back through the compressor wheel. Its the same in a supercharged car. you can have the engine revving at 5000rpm on light throttle and it will not be making any boost. It will only boost when load is applied and it will keep building and building until a certain point until the wastegate starts to bleed off the excess exhaust gas. Without a wastegate the boost would keep rising until engine failure. |
16-08-2005, 01:39 AM | #14 | |||
16-08-2005, 06:43 PM | #15 | |||
16-08-2005, 06:56 PM | #16 | ||
ive got headers hi flo cat a resistor in my air sensor
on the highway i average around 8L/100k i do a lil bit more city driving than highway and my average usually sits around 11-12L/100K |
16-08-2005, 06:57 PM | #17 | ||
oh yeah its a 6
and that involves using as little throttle as possible at all times haha |
16-08-2005, 06:59 PM | #18 | |||
car that goes (just) <----- gonna be MENACE so :thebirds: |
19-08-2005, 12:07 AM | #19 | |||
ooga-lagga-ligga-lagga
just 4 interests sakes, the 800HP CAPA supercharged BA XR8 ute got 14.2L per 100ks on a 2400km journey. with severel bootfuls to pass "double-semi" trailers... |
19-08-2005, 08:14 AM | #20 | ||
BUILT FORD TUFF
Its got dual row injectors so 12 injectors fire on full throttle, so whats a v12 550hp engine like on fuel at full throttle,i dont want to think about it
19-08-2005, 07:43 PM | #21 | |||
its not a!
Eg, having a second row of injectors controlled by another cheap "piggyback?" ecu?? Im in the planning stages for a turbo setup, and have been researching the fuel system options...
-93'ED XR8- 5-spd Charcoal Black ohh yeeah
