Old 18-08-2005, 07:03 AM   #1
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Turbo Falcon
Ok I know there are a few guys in this forum who have Turbo Falcons and I want to do the same!!!
I woud like to know what turbo's you used, what intercoolers, if you changed any ECU things where you got the manifold and so on
the other thing is if any of you guys have these bits for sale then Im keen to buy!
Cheers :
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 08:38 AM   #2
Rmyers
Does Steve have a car?
Rmyers's Avatar
With my fuel setup (supercharged), i opted to go straight gas. I got my gas research setup for just under $3000, and that includes dual convertors/lines (good for 350rwkw+), gas research throttle, new gas tank, installation costs etc etc. With a petrol setup you'd be spending about this much anyway (aftermarket ecu, injectors, fuel pump etc).
Reason i went gas is that it will pass emmissions with flying colors (provided it's running straight gas and not dual fuel), while you might have troubles with the petrol setup. The power difference between petrol and gas is minimal, and with rising petrol prices, gas is a pretty good option.
Also, if you remove your petrol tank, you will have enough room to fit dual exhuast outlets :P
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 09:07 AM   #3
dansedgli
dansedgli's Avatar
While it will pass emissions you will still need to take a $3000 ADR 37 test to prove it. And its not as easy for a gas car to pass emissions as you would think. Compared to an injected car its much closer than people will have you believe. After speaking with the EPA and various engineers the straight gas voided emission testing thing really only applies to pre 1986 cars.
Also you can easily spend over $3000 on a petrol setup if you want big power.
An ECU tuned and installed can easily hit you up for $2500, add to that injectors, I ppaid $1200 for mine, a big fuel pump, surge tank and everything else if you need it and your up for big bucks.
I have a feeling my next turbo project will be in a pre 1986 falcon running straight gas and fully engineered.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 09:42 AM   #4
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Turbo'd up
So who is CVE? I have noticed this CVE place has done a few cars
My goal is to run standard ECU, with a Chiptorque chip to suit the Turbo, keep the current compression, and run max 6psi (or higher as long as its tuned and safe)
I have seen people do it before and there are a few articles of sucessful budget turbo conversions. :baby bott
Old 18-08-2005, 10:00 AM   #5
gozza
gozza's Avatar
after seeing tufed and the work been done to it all i can think about now it turboing but id probly supercharge 1st cos my engine would probly die with a turbo
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 01:08 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
whats the go with an engineers cert?
it has to be vicroads approved doesn't it?
is a emmisions test 100% neccisary to get a engineers test.
ie. if u were using the stock ECU, would it be deemed neccisary?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 18-08-2005, 01:42 PM   #7
dansedgli
dansedgli's Avatar
It does have to be vicroads approved, but it cant be approved by them until the engineer says its okay.
The engineer wont say its okay until it passes the emissions test.
With the stock ECU you will still need to change the fueling so you would need the test anyway I imagine.
I didnt mention the ECU when I was enquiring and they all said I needed the ADR test.
Old 18-08-2005, 10:47 PM   #8
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Cve
So who is CVE? :
Old 18-08-2005, 10:49 PM   #9
EFFalcon
Last warning
EFFalcon's Avatar
V8capri on this forum.
he's a good engine builder & tuner.
Old 18-08-2005, 10:55 PM   #10
vegabass
BASS ON BOARD!
vegabass's Avatar
Cool ill send him a PM Whoo Hooo *cheers*
Old 18-08-2005, 10:57 PM   #11
T_Terror
The Guy You Love To Hate
WTF thats outrageous with the LPG thing? Where did this myth come from then that LPG dosnt produce significant emissions and dosnt require testing for it?
Would it be easier to just drive up to Sydney to do this?
Dan what engineers in Vic have you consulted with?
T_Terror is offline   Reply With Quote Multi-Quote with this Post
Old 18-08-2005, 11:04 PM   #12
EFFalcon
Last warning
EFFalcon's Avatar
LPG does require testing... its simply easier to pass due to its already lower emmisions.
Dan considered the option of driving to NSW to do it, i'm sure he'll have a nice story to tell on that
Old 19-08-2005, 05:41 AM   #13
dansedgli
dansedgli's Avatar
all of them unfortunately.
Its not easier going to NSW but its definately cheaper considering the ADR test down here is $3K.
Old 19-08-2005, 07:50 PM   #14
TuMor
its not a!
TuMor's Avatar
Im planning a turbo setup for my EA (after the engine build)
The car is currently duel fuel...which way should i go?
It has a gas tank from an el falcon, so what would gas research cost with my existing gas tank and lines?
What has me a bit stumped is the issue with engineering and emmitions tests, im not too sure about the laws in WA, or how much it would cost to get certified
-93'ED XR8-
5-spd
Charcoal Black
ohh yeeah
TuMor is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 07:57 PM   #15
CruizinEB
why turbo charge, supper charge is better(the power is there when you boot it)
CruizinEB is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2005, 08:02 PM   #16
TuMor
its not a!
TuMor's Avatar
Turbo = Good fuel economy when not thrashing
..and how hard is it to change down a gear??
-93'ED XR8-
5-spd
Charcoal Black
ohh yeeah
Old 19-08-2005, 08:02 PM   #17
EFFalcon
Last warning
EFFalcon's Avatar
read up on turbo'd 4.0's before u go saying that ;)
there are plenty more turbo'd 4.0's then there are supercharged ones.
Old 19-08-2005, 08:04 PM   #18
TuMor
its not a!
TuMor's Avatar
A turbo'ed 2l has lag
From what ive been reading the 4l dont, they have the torque down low.
-93'ED XR8-
5-spd
Charcoal Black
ohh yeeah
Old 19-08-2005, 08:47 PM   #19
Rmyers
Rmyers's Avatar
Yer maybe if were talking about a positive displacement blower, but this is not the case with the centrifugal type (spl?)
AKA Mr Silver
Old 20-08-2005, 12:07 AM   #20
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Lag
with the current high compression im running and planning to keep with the turbo even if there is lag im still going to kick *** over most things inc Skylines and some of the quick rice burners out there
the reason falcons dont have much lag is that the I6 has a long stroke and blows enough exhaust to spool the turbo. thats why skylines and little engines have lag waiting to spool up
Nothing interesting to put here.
Old 20-08-2005, 12:31 AM   #21
InitialD
Low and Loud
InitialD's Avatar
whats supper charge :
So does this mean that with LPG, its still as hard to get it engineered as on petrol with the exception of emissions?
Old 20-08-2005, 12:36 AM   #22
EFFalcon
Last warning
EFFalcon's Avatar
getting the car engineered *isnt* hard.
its pretty much all about money.
the emmissions test is very expensive, the engineers cert isnt that pricey.
but you need to pass emmissions to gain a engineers cert.
Old 20-08-2005, 02:19 AM   #23
Rmyers
Rmyers's Avatar
If your planning to keep high compression, then i'd advise that you gas as it is more "compression friendly" due to it's higher level of octane compared to petrol.
AKA Mr Silver
Old 20-08-2005, 09:07 AM   #24
vegabass
BASS ON BOARD!
vegabass's Avatar
Default Compression
Good point ill look into that, but that will all come down to money so i might get the turbo set up first and then think about gas.
I might just turbo it wait till it goes KABOOM and then rebuild it especially for a turbo gas set up.
