Old 20-08-2005, 01:19 PM   #1
sfr rob
sfr rob's Avatar
Default Fog Light Set Up
ok guys... searched for some info.. but got JACK as per usual!
there really needs to be an alphabetical searching option, like "L" for lights, locks & hot and steamy Lesbo action.... oh.... nah, you get my drift??
i am after some help, JEFF from this forum was emailing me.. but i cant get any emails back to him.. i dont know what his username is so yeah...
i want my fog lights to come on when my park lights are on, also when i swith to full lights they will still be on.
other idea i had was to have a SWITCH on the fuse box cover or something similar.
Also what would you guys think of RE-WIRING my HORN.
My horn pad has some serious problems with coming on in the middle of the night, stays on after you push it etc etc.... and i really dont feel like getting ripped off by ford for a new backing on the horn.
would it be possible to wire up another push button somewhere on the box or something like that? my neck is getting sore from sticking my head out the window and abusing people all the time!
Any help would be sweet!
Rob
Old 20-08-2005, 02:13 PM   #2
JC
JC's Avatar
Two Jeffs I know of - T3Man or XACoupe. I'm guessing it was T3man though.
As for witing the lights, you need a switch inside the car and you should use a relay (but don't have to).
Simplest wiring is to tap into parker circuit, run a wire to a switch in the car, then run a wire to driving lights. That way, when your parker are on and the switch is on, the driving lights will be on. When you go to full beam, the lights will still be on as the parker stay on too.
With a relay setup - I'll get back to you.
Ford Performance Club ACT
Old 20-08-2005, 02:20 PM   #3
sfr rob
sfr rob's Avatar
yeah T3 man!
Old 20-08-2005, 02:34 PM   #4
JC
JC's Avatar
Relay setup goes like this:
Parking light circuit to switch.
Switch to relay (pin 86)
Relay to Battery (Pin 30)
Relay to earth (Pin 85)
Relay to driving lights (Pin 87)
Old 20-08-2005, 03:19 PM   #5
sfr rob
sfr rob's Avatar
thanks JC. not exactly 100% confident on trying this my self, need to get a mate to help i think!
Can you just grab the wiring loom from the headlights and "piggyback" a couple of wires down to the foglights? i am sure you could yeah?
any suggestions for the horn idea though?
thanks mate
Rob
Old 20-08-2005, 04:37 PM   #6
JC
JC's Avatar
Rob - yes you "can", but it's not legal. Not worth getting defected for the sake of $30 worth of wire and a relay, and a bit of time to fit.
As for the horn, I would remove the airbag and fix the problem. Just disconnect the battery first. And you will need a 6 sided torx bit to undo the screws that hold the airbag cover in. You could rewire the horn to a momentary/starter button (ie only works when you press it) on the dash, but you would still need to get in behind the airbag to find which wires work the horn anyway.
Old 20-08-2005, 05:22 PM   #7
Panda
XR6 and XR8 Club of QLD
Aren't the park lights switched on/off on the negative (black) line?
Panda
Car - Ford Falcon XR6 Turbo
Panda is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2005, 05:26 PM   #8
JC
JC's Avatar
Panda
Not if they're wired correctly.
Old 21-08-2005, 01:25 AM   #9
Steve_T
You shouldn't try and piggyback the foglights to run of the headlight wiring - apart from poor performance due to voltage drop, you risk overloading the headlight wiring loom and melting something (or at least blowing a fuse) - the headlight wiring from factory is minimal as it is for it's purpose. For safety's sake always run a fuse for your foglights (in the wire from relay to bat+) and make sure the wiring/relay you run is rated greater than the fuse.
Is it an AU? If so, then for removing the airbag module it's actually a size 30 security torx plus bit (5 splined bit with a hole in the end). Well I know this is true at least fot AU2/3 anyway.
Steve.
Steve_T is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2005, 01:57 AM   #10
JC
JC's Avatar
Steve - you are right. It is the 5 sided,not 6 sided, torx bit.
If you run the lights off a relay, then power actually comes straight from the battery - you only plug into the light circuit (via a switch) to trip the relay to the on position. And yes, a fuse is always a good move.
Old 21-08-2005, 02:53 AM   #11
Steve_T
Ahh, no probs - I was thinking he may have meant just running the wires from the foglight globes straight to the headlight globe wiring and run both lights parallel of the same connector so to speak.
Old 21-08-2005, 11:17 AM   #12
sfr rob
sfr rob's Avatar
ok i wont piggy back the lights from the loom, i will make up a whole new thing with a switch in the car.
can someone please explain EXACTLY what i need?
and maybe a bit of a drawing explaining how you need to wire it up.
i havent done any electrical stuff before, but it shouldnt be too hard with some directions!
the horn thing...
can i use the same sort of set up as the fog lights for the horn?
I dont want to play around with the airbag, and i dont want to spend huge $$ at ford getting it fixed!
thanks fellas
Rob
rob
Old 21-08-2005, 12:02 PM   #13
GT290
GT290's Avatar
Just a small bit of advice before you go to the trouble. It is illegal to drive with you fog lights on. NSW its a $70.00 fine...down here I am not sure but its is illegal and if they are having a bad hair day the buggers will do you. Same with driving with park lights hence the name park lights...thats when you use them, when you are parked on the road side. Yes I have been pulled up at an RBT and thats what was told to me. Any way...just thought I would mention it after all, the less reasons they have to stop you aye.
Blue Power Enhanced
GT290 is offline   Reply With Quote Multi-Quote with this Post
Old 21-08-2005, 01:38 PM   #14
JC
JC's Avatar
What you will need:
Some 15Amp (minimum) wire - approx 6m should do.
A 15Amp (20 or 30Amp is better) relay
A switch (Illuminated or standard toggle)
some female spade connectors (approx 12)
Crimpers or pliers.
Optional - heat shrink tubing, circuit tester
Diagram attached as well - modified from the one Evil Chief posted in another thread (thanks Evil Chief).
Old 21-08-2005, 03:03 PM   #15
sfr rob
sfr rob's Avatar
thanks so much mate!
i appreciate it!
so that is the set up i would use to have a switch in the cabin yeah?
that seems pretty simple to me!
do you think you could use the same set up for the horn. as in: have another wiring set up like that but instead of the lights... you go to the horn?
thanks again mate!
Rob
Old 21-08-2005, 03:28 PM   #16
JC
JC's Avatar
Yep - that's how you connect air horns, so I guess you could re-route a normal horn the same way.
Old 21-08-2005, 03:50 PM   #17
sfr rob
sfr rob's Avatar
sweet!
your a gun!
cheers
Rob
Old 21-08-2005, 05:55 PM   #18
Bucknaked
Bucknaked's Avatar
Whats the expected finish date till you get your kit together. I'm very keen to see the end result
Old 21-08-2005, 10:26 PM   #19
sfr rob
sfr rob's Avatar
yeah i want to know the EXACT same thing... see its a good mate that is doing it and i dont want to rush him, but i asked him today he said HE wants to get it done by next weekend.. so hopefully by then mate!
cant handle not having a run about car!!!
Old 22-08-2005, 12:05 PM   #20
T2TL50
Proud Owner of a T 2TL50.
T2TL50's Avatar
I am sure you knew this but i though it would make it clearer.. lol
The au series use a special "ford only" torx bit.. a 5 Sided one... the 6 siders dont fit they are for sale at some of your specialty tool shops for a pretty penny... hence i have one they come in handy!!! cheers
One Of Fords Finest Cars!
The T2 TL50!! Maybe You Will Own One, One Day!!
T2TL50 is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 12:42 PM   #21
sfr rob
sfr rob's Avatar
thank you sir, where would i grab one from? any tool shop?
Old 22-08-2005, 12:47 PM   #22
JC
JC's Avatar
Yeh, thanks. Now my error has been pointed out twice (Steve T already picked this up earlier in the thread). Sometimes it pays to read the whole thing first.
Having said that, it is only these two torx screws that I know of that require the 5 sided bit (but a notched screwdriver works just as well!). Every other torx screw/bolt is the 6 sided variety.
Old 22-08-2005, 09:40 PM   #23
T2TL50
T2TL50's Avatar
Default Torx Bit
I guess thats one of fords ups.. lol.. / security things.. they are buggers..
sorry i coul dnot be bothered reading the whole way... it is so simplt to add foglights with a relay.. lol.. but i guess that i dont understand people dont have the sames views as i do..
and i am getting used to the fact not every one know everything about electronics out new age cars have..
Old 23-08-2005, 09:57 PM   #24
sfr rob
sfr rob's Avatar
yes...not EVERYONE is an electrician here on the forums mate!
what the hell are you on about???
"and i am getting used to the fact not every one know everything about electronics out new age cars have.."
Old 24-08-2005, 06:29 AM   #25
Bucknaked
Bucknaked's Avatar
Electronics? Whats that? My mechanic works on my car. He can concern himself with all the nerdy electronic stuff.
Old 24-08-2005, 01:07 PM   #26
JC
JC's Avatar
Bucky - I am NOT your mechanic! Just someone who helps out on your car from time to time. Especially in relation to setting up foggies - If I remember correctly, I even let you help: "Here Bucky, hold the torch so I can see!" LOL.
Old 24-08-2005, 06:43 PM   #27
Bucknaked
Bucknaked's Avatar
Yes you are. You do everything to my car except change the oil, hold the torch and empty the ash tray. Your always trying to remove parts and replace em with something different
Old 24-08-2005, 08:10 PM   #28
sfr rob
sfr rob's Avatar
hehehe.....
you seriously need to get your hands a bit dirty mate!!
hey JC!.....
i dropped into JAYcar and bought all that stuff you said i should get..
got a nice little switch too!
so hopefully my old man has time on the weekend to put this together with me...
got to get my new amp and subz installed on the weekend too!
Also you will never guess what...
My mate that is painting my new kit came around with side moulds, mirrors the other night, and we put them on all painted up...
this morning i got out to see in the light... and the friggen losers at the paint mixing joint stuffed the color up!....
lucky he only did the small bits, imagine if he had gone and done the whole lot then found out the colour is lighter than my panels paint!!!!
that said..... i am looking at ANOTHER WEEK till my car is ready to cruise in again... sucks having your car off the road for a month!!!!!!!!!!!
thanks for listening fellas!
Rob
Old 25-08-2005, 02:33 AM   #29
Steve_T
Just to quickly clear up a point regarding the few posts on the 5/6 sided torx bits 'cause I've seen similar posts before too:
5-sided torx is not a Ford-only thing - the 5 sided bits are just a 'new improved' version of the original 6-sided torx. It is an industry standard and they are called TORX PLUS as oposed to 6-sided ones which are just called TORX. Both also come in a security version which has a hole in the end of the bit. Both come in common range of sizes. The fact you don't see Torx Plus used on many things is no accident - it was developed as a new high-security standard when Torx started to become popular for general use and was always intended as more of a limited use for security or critical fastener applications etc.
sfr_rob - bugger about the paint work. Just to note again on those lights - in that diagram, a fuse would go inline on the wire running between relay and battery positive. I only say this again 'cause I know of people who have wired up things without fuse protection and have been unfortunate enough to regret it (think: flames :/ ) - it can happen.
Steve.
Old 25-08-2005, 04:41 PM   #30
sfr rob
sfr rob's Avatar
I want to put the lights in... but i have no idea!
i think i might need to take the car to an electrician friend of mine once the kit is on, and he can stick it all together for me!
yeah mate not happy about the paint mate!
its a real pain in the ****, driving my truck everywhere, it isn't a happening thing!
ing_sm
