Old 31-08-2005, 09:05 PM   #1
Rmyers
Does Steve have a car?
Rmyers's Avatar
Default New way to mount your battery ;)
Since i got the gas tank installed, it has taken up quite a bit of my boot room, which means their is less room for all the audio gear i have to go in there. Problem # 1 is the two optima batteries which take up a fair bit of room and are awkward to find a spot for, and problem # 2 is they must also legally be externally vented to pass a roadworthy.
Solution?? They are going to be mounted underneath the car were the fuel tank used to be. Gave Vic roads a buzz and they say that aslong as there is enough ground clearance, that they are sheilded in some way and that they are properly secured, it will be fine. I will be looking into it a little further tho to be absolutely certain that it is legal, but from what i've heard so far, it's good to go
Can anyone see any problems with this kind of setup?? Anyone had any problems legally with doing something similar??
AKA Mr Silver
Chasing reliability....:
"When Chuck Norris jumps into water, he does not get wet, the water gets Chuck Norris..."
Rmyers is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 09:06 PM   #2
neb
hibernating
neb's Avatar
Well you would want to keep it as far away from exhaust as possible so they don't get too hot... and yeah enough clearance and properly mounted and shielded should be fine!
neb is offline   Reply With Quote Multi-Quote with this Post
Old 31-08-2005, 09:07 PM   #3
LUXO_8
windsor user
sounds like an awesome solution steve, nicely hidden away under the car, allows more room in the boot for the install
Old 31-08-2005, 09:11 PM   #4
Rmyers
Rmyers's Avatar
Only problem is that i will most likely be ditching the dual exhaust idea, but i've been thinking that for a while as i'd rather spend money elsewere....
AKA Mr Silver
Old 31-08-2005, 09:11 PM   #5
niko
likes falcon's
niko's Avatar
2 batteries??? jeez man, how much power your equipment need?
wat u doign with the spare wheels home?
www.carhubsales.com.au
Old 31-08-2005, 09:19 PM   #6
EFFalcon
Last warning
EFFalcon's Avatar
i reckon rmyers is gunna need a 200amp alternator soon enough lol.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 31-08-2005, 09:20 PM   #7
Rmyers
Rmyers's Avatar
It's more so i can play the stereo when the cars turned off eg drive ins. (plus i have 4 amps to run (with a 5th looking tempting :P))
The spare wheel well will be used as the sub enclosure....
(wheel well will, sounds funny when you repeat it to yourself :P)
AKA Mr Silver
Old 31-08-2005, 09:22 PM   #8
LUXO_8
windsor user
lmfao, you're a crackup dude
:Up_to_som
Old 31-08-2005, 09:45 PM   #9
InitialD
Low and Loud
InitialD's Avatar
Its a shame that your going to be ditching the dual exhaust :(
But sounds like the best idea ;)
Old 31-08-2005, 09:49 PM   #10
niko
likes falcon's
niko's Avatar
put a fake tip there? :P
Old 31-08-2005, 09:54 PM   #11
Rmyers
Rmyers's Avatar
Nah no rice stylez for me, either real or nothing....
AKA Mr Silver
Old 31-08-2005, 10:01 PM   #12
Damo
That sounds like it would work well. Most trucks have there batterys mounted on a tray under the body so I don't see why a sedan couldn't.
Old 31-08-2005, 10:04 PM   #13
niko
likes falcon's
niko's Avatar
but there designed for it and usually there raised a fair bit, good luk with it, make sure u post up pics when u start doing it
Old 31-08-2005, 10:16 PM   #14
sphell
sphell's Avatar
ya beat me to it, exactly what i was gonna say! I don't see there being a problem, you'd just want to make the sheild so they don't get too wet I reckon.
Old 31-08-2005, 10:25 PM   #15
Rmyers
Rmyers's Avatar
Here's a pic of the room i have to play with...
For those that don't know, i should have mentioned that they are SEALED lead acid batteries, so they can be mounted on their side (which will allow more ground clearance).
AKA Mr Silver
Old 31-08-2005, 10:28 PM   #16
LUXO_8
windsor user
maybe, sheetmetal frame, and open at the top for access?
so that way the batteries arent "outside" so to speak??
Old 31-08-2005, 10:40 PM   #17
Walkinshaw
Two > One
Walkinshaw's Avatar
You know you want a drop tank lookalike!
Old 31-08-2005, 10:46 PM   #18
Rmyers
Rmyers's Avatar
I'd be lying if i said it hasn't crossed my mind ;)
AKA Mr Silver
Old 01-09-2005, 12:55 AM   #19
montyv8
Turbo Dinosaur FTMFW
montyv8's Avatar
if you go ahead with it, make sure theres a decent thickness skid plate underneath.
just in case...
1973 XB Fairmont Coupe, turbo EFI SBF
8.23@168MPH
montyv8 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:27 AM   #20
Stevo
Sounds fair enough, Only problem I see Vic Roads having with itis the batteries covered up under the car, is for when you total it, and Fire'ies need to unhook your battery.
Heritage Green EL Ghia
Black AUII XR8 Ute
Stevo is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:48 AM   #21
Rmyers
Rmyers's Avatar
That word should be IF :P
AKA Mr Silver
Old 01-09-2005, 02:18 AM   #22
Stevo
lol, true . My bad
Black AUII XR8 Ute
Old 01-09-2005, 07:47 AM   #23
bindi
Redhead extraordinaire...
bindi's Avatar
Good god... that is some serious audio! Do you get pulled over by the fuzz often then? And the most important question, DO YOU PULL CHICKS? :evil_laug
Bindi
88 EA- his car
88 Rolla - MY car
Originally Posted by big_waity
Oh, and another surefire symptom will be the Falcon badge at the back.
bindi is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 08:38 AM   #24
EA2BA
PM me if you want
EA2BA's Avatar
Why not get a second spare wheel well and weld that in, the cut the floor space out, and weld a steel plate into the bottom of it, and put cover over the top of that.
Old 01-09-2005, 09:53 AM   #25
NZ
NZ's Avatar
Your not one for cutting up the body of your car are ya?!! lol
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 01-09-2005, 10:00 AM   #26
EA2BA
PM me if you want
EA2BA's Avatar
I really havent cut that much metal in my car, 2 holes in the guards for the side repeaters, and a very minimal cut for the BA shifter to fit.
But I am not shy to pull out the angle grinder and jigsaw if needed.
Old 01-09-2005, 11:57 AM   #27
old_mate
Smash the Boost
old_mate's Avatar
If anyone remembers, Street Machine mounted their 2nd battery in a tray thing they built under the backseat on the EA Sony Scorcher thing they built. Was a good thing they built too
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 03:40 PM   #28
Rmyers
Rmyers's Avatar
Kinda hard to pickup when for the last 2 years, i can only describe my car to them :P
AKA Mr Silver
Old 01-09-2005, 06:10 PM   #29
niko
likes falcon's
niko's Avatar
just dont tell em its a ford ;)
Old 01-09-2005, 07:19 PM   #30
Psycho Chicken
Psycho Chicken's Avatar
Simple, isolator switch and a big orange triangle. Or was it blue? I dunno haha.
