Old 01-09-2005, 11:49 AM   #1
DUMTEF
DUMTEF's Avatar
Default EF Histall and Limp Home Mode
Hey guys,
i know this has probably been asked before but i cant find anything about it, i rang jim mock this morning and asked them about my car going into limp home mode if i was to install a histall, and was told that on a ef it wont occur. and also the automatic joint up the road from me said he had never heard of it occruing on a ef.
does anybody know anything about this.
cheers adam
DUMTEF is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:31 PM   #2
Supa R00
Rolling on Simmons...
Supa R00's Avatar
Yeh ive seen one in an EF... it was a 2500 stally and would constantly go into limp home, could never get the solution so the guy went to a manual. I suspect dodgy install or something was going on but it had the mechanic at his wits ends, went awesome when it worked though! :P
The daily hack...
1994 ED
XR6
5Spd, Simmons FR17"s, SupaLow's, Sprint Bodykit,
Cam, exhaust and all that jazz... Complete AU XR6 conversion and soon to be turbo!
:voldar02:
Originally Posted by Walkinshaw
When has any XR6 after the ED, prior to the XR6T been anywhere near being a performance car, or much more of a car than a stock taxi spec Gli?
Supa R00 is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:34 PM   #3
DUMTEF
DUMTEF's Avatar
that sucks cause im looking at maybe going 2800rpm, but i also rang chiptorque and was told that there is something that lachlan can change to solve it.
Old 01-09-2005, 01:35 PM   #4
Simmo
White Lightning
Simmo's Avatar
what about disconnecting the wires in the loom that report the status of the box/controller unit and putting those resistors in like you do with a manual conversion?
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:37 PM   #5
DUMTEF
DUMTEF's Avatar
wouldnt they be the same wires that control the box, correct me if im wrong as i dont know a great deal about this stuff
Old 01-09-2005, 01:40 PM   #6
Laminge
Cuban... nothing like it
been running a JMM highstall in my car for a couple of months and only under extreme dragging at heathcote that it went into limp home mode, oil overheated basically
Originally Posted by Laminge
...its amazing how mud sticks to ones shoes, as flies do to the elderly and bottle blondes around fame and fortune...
Laminge is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 01:43 PM   #7
DUMTEF
DUMTEF's Avatar
laminge, what car are you running this in, and what stall speed?
Old 01-09-2005, 01:44 PM   #8
Laminge
sorry
Au6., and its the JMM 3000 i believe.
Did you chat to Brendan or Jim?
Old 01-09-2005, 01:50 PM   #9
Walkinshaw
Two > One
Walkinshaw's Avatar
Aaron has a TCE 2500 converter which stalls up at 2800rpm and flashes over 3000 and he hasnt had any problems yet. However the same stall cause limp home in an EDXR8....Could have something to do with the vortech pushing the stall over 4000rpm
Old 01-09-2005, 02:08 PM   #10
DUMTEF
DUMTEF's Avatar
when i rang jmm i spoke to brendan. and yeah he said id only run into problems if it was going to like 4000rpm
Old 01-09-2005, 02:14 PM   #11
Stav
Smile
Stav's Avatar
Our transmissions are safe with a flash stall of around 2500 rpm with lockup on the street .With more torque the flash stall speed will be higher.If you plan on going higher expect to use heaps more fuel and get more slippage of the stall.
Old 01-09-2005, 05:23 PM   #12
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
a mate has a hi stall in his eb and he's running a turbo and his use to go into limp home mode but he fixed it buy putting a EL ecu in it ,he said ford told him that they wont go into limp home mode and far far it's worked ,so yeah maybe try a EL ecu instead
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 05:42 AM   #13
eb six on boost
NO CARBON TAX
eb six on boost's Avatar
yeah i put an el comp into my eb, i know its different as your ef has coil pack so you would need and aftermarket fuel/ign computer.
i also tried putting two resistors in to replace signal from temp sensor and it didnt work.
keep in mind i have 2 oil coolers and twin thermo fans on them aswell.
good luck
THE WORLDS FASTEST BISCANYE BLUE EB FALCON WITH EB BLOCK AND HEAD!!! NO AU **** THANKS
Atomic performance engine, powerglide, coan converter, gtx55 turbo, 2000hp plazmaman water to air, 100mm throttle body, twin 50mm gates, side exit exhausts, 18 x 2200cc injectors, ems 8860 and race dash.......
7.83 @ 177 MPH
1100+ rwhp @ 40psi
the first 7 second sohc ! eat it
1993 eb falcon 15.4 @ 90mph (tow car)
eb six on boost is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 08:41 AM   #14
Kenaz
Kenaz's Avatar
You can't use a EL ECU in a EF.
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 08:54 AM   #15
DUMTEF
DUMTEF's Avatar
thanks for the help guys, i think ill just get the 2800 stall and if i run into problems i will get chiptorque to have a play with the chip. then time to save for 3.7's
