BA xr8 2004
does anyone know where to hook up the input wire for a tacho on the EA. it would be appreciated.
Road Runner
if its an aftermarket tacho eg auto meter i would presume its the same as always to the negative (-) of the coil. If its the tacho in the cluster i wouldnt have the foggist.
#3 | |||
*Smart *** comment here*
1997 4.0L EL Falcon GLi Sedan Auto ---------------------- 2.5" Cat Back Mandrel Bent Exhaust to Two Lukey Sports Mufflers and a 3.5" Dump Pipe Lowered all round on King Spring Super Lows Tinted Windows, Pioneer MP3 Player and Audio System K&N High Flow Air Filter Mounted in Original Air Box Trip Computer NGK Sports Performance Leads NGK Sports Plugs Autotecnica Oil Catch Can
BA xr8 2004
yeh i thought it went to the negative on the coil, but i cant seem to find the negative on the coil, it is ib a hard to reach place, under the exhaust manifold
BA xr8 2004
does anyone know where on the coil the negative is?
intake manifold u mean:P
Fairmont6
negative on the coil, well theres the earth wich earth to the egine, im pretty sure the negative would be in the plug that plugs on the back of the coil under the intake manifold, best use a hoist too so much easier to deal with coils on flacons from underneath
There is a little wire which runs from the distributor to the coil...It has a connector about halfway alog..You could take a feed from there as that is the negative you are looking for.
Be aware there are some after maarket tacho that have to be connected to an auxillary feed line up near the brake booster rather than the coil. Have fun ![]() |
FPV GT-P 335!
There is a pink wire from memory which ends up in a loom near your brake booster. Its a diagnostic loom which isn't used, so you can normally just hook into that....nice and easy.
Current rides - 2013 FPV GT-E MK2 & 2010 FPV F6-E Tuned by Michael J's & Son. |
hmmm boost
pink and white wire in the dianostic port near fuse box near right knee
EL TURBO GHIA GT3582R WOLF3D TUNED BY JEM |
BA xr8 2004
thanks for the help guys i will try them out.
