Old 16-11-2005, 07:41 PM   #1
STOKEB
NOS Induction pssssshhhhh
STOKEB's Avatar
Default Alternator
Just wondering guess will a series 2 ea fairmont alternator fit into a eb series 2 with out cutting or chaging looms around. ??? thanxs guys
STOKEB - 3:7 diff gears, 3inch zorst, JMM Race Series Extractors, Custom Bottom end to suit N20, AU DEV 6 Head and Cam, Cold Air Intake, ED XR6 Manual Computer with Flash Tunner, ED XR6 Fuel reg, C10 Auto, 2800stall .
I LiVe My LiFe A bOtTlE aT a TiMe, FoR tHoSe 200 sQuIrTs I fEeL fReE.........pssssssssssssshhhhhhhhhhh
STOKEB is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2005, 08:29 PM   #2
EDXR6T
dont c y not it should fit up i dont c y the loom would b n e diffrent
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 16-11-2005, 08:37 PM   #3
John_LS1
you will need an adapter loom that goes from the mitsubishi style altenator to the bosch style altenator. i think you can buy these seperate or make up your own.
Old 16-11-2005, 09:34 PM   #4
InitialD
Low and Loud
InitialD's Avatar
Correct John, Most Autoelectricians have the Mitsubishi to Bosch Adaptor plug. Just not the other way around unless you make your own like I have done in the past
Old 17-11-2005, 12:38 AM   #5
STOKEB
STOKEB's Avatar
i just tried to fit the bosch alternator to my eb and it wont fit, the bracket seems to be smaller for the mitsue. Ill have to get a bosch style bracket as well, the wiring isnt the problem just mounting it, ive converted the plugs.
Old 17-11-2005, 06:56 PM   #6
John_LS1
the brackets are the same, i thought that to at first but it turns out all you have to do is loosen off all the bracket bolts and just move it around untill the holes line up for the new altenator.
