Old 02-12-2005, 11:15 PM   #1
ford girl
Default THe other half needs help
HE's wiring a tacho into his VP crumbledoor, He has all the wires hooked up he's just not getting signal. That's as much as I can be bothered saying, I don't like wasting my time on crumbles, but he needs help and it shis pride and joy. Any one willing to give some advice?
ford girl is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 11:45 PM   #2
Blue Oval Mopar Man
Has Blue Blood
Blue Oval Mopar Man's Avatar
Yes < I have delt with this type of problem before !
Tell him to sell it for as much as he can (I know thats not much ) and put it towards buying a FORD ! And be good to his Mum ! :
Real cars dont wear bowties
I'm not arrogent , Just superior
Blue Oval Mopar Man is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2005, 11:51 PM   #3
deesun
deesun's Avatar
Take him out a box of redheads and 4ltrs of unleaded,that will fix it.yes it will.
He will thank you for it later. And if he doesn't we will. :
igodabigblackshinycar and I relented and allowed a BMW into the garage.
deesun is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 12:07 AM   #4
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Tell him to cut the red wire...or is it the blue wire?? :dr_Evil:
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 12:11 AM   #5
Bobman
Regulator
Bobman's Avatar
I'd never go out with a holden-nut girl
Regards
Bobby
Current Cars:
2000 AU2 Fairmont (2019-current)
2003 BA1 Falcon Divvy Van (2017-current)
2009 VW Mk6 Golf 118TSi (2020-current)
Previous Cars:
2003 MCX10R Avalon VXi (2017-2020)
1995 EF1 Falcon GLi (2016-2019)
1997 XH2 Falcon Van OPT20 (2016-2019)
2006 BF Fairlane Ghia (2013-2018)
2001 AU3 Futura (2010-2013)
1996 EL Fairmont (2008-2010)
2004 BA XR6 (2005-2008)
2001 AU2 Forte (2005-2006)
1988 EA Fairmont Ghia (2003-2005)
1984 AR Telstar TX5 Ghia (2001-2005)
Bobman is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 12:15 AM   #6
luke
on a serious note, where's he connected the green (signal) wire?
Still think he should have bought a ford though
2003 BA XT Wagon, I6, 4sp Auto, Dual Fuel, Prins Autogassystemen VSI LPG
RIP:
EA S MPFI 5 speed sedan w/exhaust, LSD, tint, 225's, DBA Golds, EL twin thermos, dual fuel and fluffy dice ; Stolen, recovered and written off, 7th April 2007
luke is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 12:41 AM   #7
XHII V8S
I've had this problem with my old ute. Depends on where he has hooked it up. There are two places, directly on the coil or on the signal wire that feeds to the dash. Even if it doesn't have a factory tacho they are still wired up for it. This is the best place to connect it. Tell him to check that the tacho is getting power first, then check his connection to the signal wire, and maybe consider soldering it.
1998 XHII S Longreach V8 - 16.648 @ 133.65km/h
-XR8 Rims
-Blackout Tint
-Pioneer HU
XHII V8S is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 12:49 AM   #8
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
wouldnt you make sure the tacho is wired up right before soldering... tape is a whole lot less permenant than solder!
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 12:53 AM   #9
ford girl
Yes I know. On a more serious note, does anyone know how to get a signal out of dfi. Its not getting signal from anywhere
Old 03-12-2005, 01:36 AM   #10
clontarf_x
geez I knew holden were cost cutton but no taco signal? now thats just MAD
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 08:19 AM   #11
Stampy
What will a Holden driver do without a tacho and a shift light ,poor guy won't no when to change gears , bet he's got a monster tacho so he can see the numbers easy.
Ford girl teach him to listen to the engine ,feel the engine ,be the engine then he won't need a tacho and he can spend nore money on you .LOL
Old 03-12-2005, 08:37 AM   #12
64compact
he needs a tacho so he can tell when to lift his legs when the eng puts a leg out of bed. ..... use the tacho wire behind the dash. the printed curcuit has Tacho on it. but make sure you set the shift light to 1,500rpm so as not to over rev it and break a PUSHROD.
64compact is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 08:38 AM   #13
gravelrash
on the lh side in the engine bay between the shock tower and the firewall. follow the harness back to the firewall and you will find a little single plug taped to the harness. that is the tacho signal wire on commodores. if i can find a commodore i would take a pic for you.
cheers Greg
gravelrash is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 09:23 AM   #14
ford girl
Tried all them, and he needs it cuz his stereo is to loud. no wire is giving out signal, i reckon the wiring is ed. But im a ford girl so what would I know?
Old 03-12-2005, 09:28 AM   #15
AUSGTI
Das Auto Bitches!
AUSGTI's Avatar
Hhaha, even my mates 74 Volvo has a factory wire for the tacho!! (it didnt have a tacho in it before he put one in)
MY14 MK7 VW Golf GTI - waghoon!
AUSGTI is offline   Reply With Quote Multi-Quote with this Post
Old 03-12-2005, 09:31 AM   #16
ford girl
It does have a factory wire. no signal.
Old 03-12-2005, 10:33 PM   #17
Bossxr8
Peter Car
Bossxr8's Avatar
He'll be able to feel the engine as soon as he starts it, those early V6's are the harshest, most rough as guts pieces of garbage ever invented. LOL.
Old 03-12-2005, 10:44 PM   #18
Redrum
Force Fed Fords
Redrum's Avatar
He will still have his fluffy dice and 6x9 sprinklers in rear parcel shelf!!
Redrum is offline   Reply With Quote Multi-Quote with this Post
