Old 20-12-2005, 02:57 PM   #1
need psi
slow & low EA Ghia
need psi's Avatar
Default battery in the boot setup, who's done it?
hey guys just wondering whos put there battery in the boot of there car? ive put mine in but now my car doesnt seem to want to start!!! did any one have any probs with voltage drop or any other probs? also where did you earth the battery too? pics would be good too.
Thanks
Ehab
Ea Fairmont Ghia 1988
need psi is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 03:02 PM   #2
Obriza
Obriza's Avatar
i would like to know this too as im thinking of putting in an extra battery into my boot too
Obriza is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 04:27 PM   #3
TUFED6
TUFED6's Avatar
Heres how i did it-
Make sure you use really big cable (like welding cable). Alot of the relocation kits around use fairly small cable that isn't really up to the job. Run it straight onto the starter motor positive.
Get a terminal block and mount it in the engine bay where the battery used to be, then connect all the stuff that used to be connected to the positive terminal to it. In effect you are using the old starter motor power cable to run the accessories.
I earthed mine on the body in the spare-wheel well (battery is in the spare wheel well). Seems to work well, I don't have any earthing problems.
- John
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 04:29 PM   #4
tickford2001
yep john has picked up on a good point, you need a decent cable running through.
i earthed mine to the body/sub frame just near where the bumper bolts go through from inside the boot
Gone cruising
tickford2001 is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 04:33 PM   #5
jd dad
Same as I did used heavy welding lead and got good ends cramped onto it. Just earth it onto the body inside the boot somewhere. Ran an extra earth from where the starter bolts on, onto the body as well.
successfull trades with davway,ozziechief,Damon, Big Trev, Howey, BJ , Niko, Davocol,klawsterfobik and XCwillo
jd dad is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 05:04 PM   #6
efgiar
rofl copter
efgiar's Avatar
yeah nice big fat cable is the way to go. use cruddy small one and ull be dissapointed, if u wanted to set up a kill switch type thing, run a small constant wire (from batt +) to ur radio to remember all the stations, then have a solenoid between the battery and the starter, will kill the car completly so no one could do anything
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 05:44 PM   #7
Walkinshaw
Two > One
Walkinshaw's Avatar
Look at getting 0/1guage atleast. The wire should be ATLEAST as thick as a garden hose
Old 20-12-2005, 10:41 PM   #8
need psi
slow & low EA Ghia
need psi's Avatar
dan you've seen it, it aint small but im still concerned about it dropping voltage. i bought it from sprints, its made by narva i think and it was under the truck battery cables i think, cant exactly remember how many amp meters it was suppose to support but 300 comes to mind.
tufed6 - the guy who rewired my engine bay already done everything you just said, and told me to run the wire off the starter motor to the boot. i got the earth strap were the rear bar bracket bolts in through the floor next the rh tail light, is that good enough?
were did you get the welding wire from? and how much did it cost?
Thanks
Ehab
Old 20-12-2005, 10:46 PM   #9
Clarke AV
OzECruisers Treasurer
Clarke AV's Avatar
Putting the battery in the boot means adding weight to the car, hence large copper runs from front. Copper is heavy to compensate for the 400 cranking amps you need to get to the other end. Plus I put it in a marine battery box so it doesn't rot whatever it sits on. I think the only reason you'd want to put it in the back would be if you had run out of room in the front. What are you trying to do?
Clarke AV is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2005, 11:31 PM   #10
need psi
slow & low EA Ghia
need psi's Avatar
http://photobucket.com/albums/c392/papaghia/
check out the pics... no room in the engine bay. plus the battery is in a box that has been drilled to the floor of the boot behind the rh tail light.
Old 20-12-2005, 11:47 PM   #11
BELTA
belta kix lsss!
BELTA's Avatar
That car is sick does it go hard?
Built Ford Tough :evil3:
BELTA is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 12:30 AM   #12
sphell
sphell's Avatar
Nice setup! Yeah i used to have a prob where the car would take about 4 goes to actually start. Definately voltage drop. Do exactly what Tuffed says....we did that to sunny's car and it worked a treat. And I'd suggest getting a circuit breaker or fuse of some sort to go at the battery end of the cable.....don't want the car going up in flames if that garden hose cable shorts out.
Old 21-12-2005, 01:21 AM   #13
XRated
Shoot.
XRated's Avatar
Damn, your EA is haaaawt!!
20V Turbo
Old 21-12-2005, 01:40 AM   #14
need psi
slow & low EA Ghia
need psi's Avatar
ahhh i dont really know...... havent driven it yet! but thats due to the gas system.
thanks for the help guys im getting an auto elec out to have a look at it, so he might be able to find out why it aint turning over or taking so long to catch when it did.
thanks for hot comment im blushing..... i know you meant the car too guys.
Ehab
Old 21-12-2005, 02:14 AM   #15
ebxr8240
Performance moderator
ebxr8240's Avatar
I earthed mine with 10mm wire at boot and 50mm welding cable to bolt at rear of gearbox and another 10 mm strap from there to body, also used original earths up front..I crimped all my wires together up front with heat shrink over them using 50 mm sq again as active wire....The brakets from the front where transfered to boot where it holts battery down as it did under bonnet..I'll soon be fabricating an alloy battery box...
This cable is that heavy it won't burn!! It'll flatten battery ...
Being a Lineworker helps as I have access to crimping tools and lags etc....
Daily driver GTE FG..
Old 21-12-2005, 06:47 AM   #16
gravelrash
have you run a earth cable from the block to the chassis??
gravelrash is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 08:27 AM   #17
LTDHO
The one and only
LTDHO's Avatar
I ran 50mm2 welding cable on mine to the starter. 2G runs the audio and 75mm2 grounds the battery.
It starts my car no prob's.
I also habe 50mm2 from chassis to trans and another chassis to engine.
Tuned by CVE Performance
Old 21-12-2005, 08:30 AM   #18
dansedgli
dansedgli's Avatar
I used the thickest guage stuff autobarn had in my EB. I think it was 2 guage. From the battery to a distribution block in the engine bay which had eveything that the old postive terminal had on it.
The ground was just the same size cable from the negative to the metal supports in the boot.
I lost 0.5 of a volt. The car still started and ran like normal.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2005, 12:07 PM   #19
ebxr8240
ebxr8240's Avatar
Yep original earth's up front pluss earth / bonding at gearbox....
Ummm? A bolted left side engine mount helps also..
Std engine mounts break...
