Old 23-12-2005, 12:25 AM   #1
gtfpv
GT
gtfpv's Avatar
Default something i've always wanted to know????
what makes a V8 sound like a V8?
QUEST 1 : why doesnt a straight 6 sound like a V8 ?
QUEST 2 : why doesn't a V6 sound like a V8 ? anyone know the technical reason ????
gtfpv is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 12:33 AM   #2
GTS_300_Coupe
Mandy Moore FTW!
GTS_300_Coupe's Avatar
My mates got a VU Commodore S ute with a custom dual exhaust setup, could almost pass as a V8 with its deep burbly note.
GTS_300_Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 12:58 AM   #3
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Got a mate with a VR commo, changed his exhaust and it really has a V8 rumble. Better than any v8 commo I've heard.
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 01:09 AM   #4
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
its to do with the stroke cycle.
a v8 will have 2 cylinders on the exhaust stroke, with 2 on the intake, 2 on the compression and 2 on the combustion (power) stroke. Therefore its all symmetrical. And which is why they're also so smooth. And why you have such a nice exhaust note, because you have 2 cylinders pushing exhaust gasses out at the same time.
Not like with a 6 cylinder, where you will have 2, then 2 then 1 and 1 pushing exhaust gasses out.
Makes sense to me, and ive been at the pub!
Mind you i have heard v6 commies that have sounded very much like a v8, and my xy wagon i had people swearing that it was an 8 too.
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 07:57 AM   #5
Hunter
Ex EL Falcon
Hunter's Avatar
I was pretty sure it had a lot to do with the firing order as well...
Oh and I've heard *way* too many V6 dunnydores which sound like a cow taking a huge dump. Either that or they sound like a cow taking a huge dump into a vacuum cleaner.
Falcon 6s always sound good.
Hunter is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 08:07 AM   #6
SunDrifter
To shreads you say?!
SunDrifter's Avatar
I think klawsterfobik is on the money there. And seeing we're getting so many my mate stories.
My old XF had a Stage 3 COME cam and Mandrel Bent Pacemakers with a 2.5" system, and she really sounded like a V8 (lumpy!).
BAII XR6 Ute (manual) Winter white.
Originally Posted by VYBerlinaV8 (LS1.com.au)
I've owned Holdens and Daewoos, and had plenty of problems with Holdens and none with Daewoos. Of course, the Holden is the more desirable car to own and drive, but based on my experience it is not the higher quality of the two.
Originally Posted by SlickHolden
Weight means nothing to a cars handling...
SunDrifter is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 08:30 AM   #7
Lukeyson
Right out sideways
Lukeyson's Avatar
yeah i find if a 6 exhaust is done on the cheap cheap or by a dodgy brother, it will sound like a tug boat. But if done well, they have some aspects of an 8 in the note, but still unique.
And i asked a mechanic that a while ago, and he gave me a similar story to klawsterfobik.
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 08:41 AM   #8
gww64
gww64's Avatar
Had an xa 6cyl that sounded like an eight. Couldn`t pick the difference. Till you drve it of course. Extractors and a twin system make all the difference. Depends on the mufflers you use as well.
gww64 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 08:46 AM   #9
Raptor
Raptor's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For quietly going about moderating in a fair and even manner.
WTF, it doesn't make any sense to me it sounds like you've been drinking.
A inline 6 cylinder (is there really any other kind) will have 1 on the exhaust stroke and 1 on the compression stroke every 120deg of engine rotation.
That other kind of 6 cylinder will have them split 60deg apart or some weird 90/30deg pattern if they are cut-down V8's
Common V8's sound the way they do because they have an exhaust pulse every 90deg of crank rotation, and this will differ depending on the firing order. There are also 2 different crank pattern, Flat-plane and Cross-plane. You'll find the Cross-plane in your everyday Ford and Holden while the Flat-Plane crank is more common in exotics such as Ferrari etc which sound quite different. Flat plane allows for lower weight (no counterbalance) and thus lower rotating mass (revs quicker) and thus more ultimate power but at the expense of harshness.
Pic's taken from here; http://www.autozine.org/technical_sc...dex.htm#Engine in the section on engine smoothness, I6 is best :voldar02:
I hope that provides some technical explanation rather than what me mates sisters uncles girlfriend car sounds like.
'93 XG Falcon Ute( sold ) : '94 ED Falcon Classic ( sold ) : '04 Territory SX TS ( sold ) : '04 Falcon RTV BAII ute (still in the family)
Raptor is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 08:48 AM   #10
masters24
I gots me a UTE
masters24's Avatar
VL Commy (boyfriends old work rig) sounded like a lumpy 8, although it was fully stock. The muffler/exhaust was a bit shagged and just sounded mean. His cousin who is a MAD holden nut hears it and goes "I didnt know a V8 would fit in a VL!" i was rather blown away...
NEW UTE!!! (Yet to be named)
XF, Duel fuel, 250X, 4 on the floor (soon to be T5 hopefully)
VDO Sound System,
masters24 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 09:02 AM   #11
YOOT
YOOT's Avatar
GO race a mate in his XR6 Turbo if you have something that will keep up and wind the window down while they are in front.
I have had this pleasure with my best friend who has a sedan, we raced back from my girlfriends house after State of Origin, since the sedan is a little quicker he was always in front from 100km/h upwards and believe me, there is nothing more spinetingling than a Barra240T at WOT from 10 feet away at break neck speeds!!! :thebirds: Sounds meaner, louder, and almost like the engine will explode than any other stock performance car in Australia :Reverend:
YOOT is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 09:38 AM   #12
Casper
Contributing Member
Casper's Avatar
My XD I6 sounded like a V8. Now, of course, we all like to think this but in this case it sounded so much like a V8 that a mechanic who owned a V8 XE insisted I pop the hood as he thought the 4.1 badges on the side were "sleeper badges" and he didnt believe me that it was only an I6.
As for modern I6's (4.0l etc), they just dont sound the same, its a totally different sound. No idea why.
Older, wiser, poorer.
Old 23-12-2005, 10:01 AM   #13
OLDFORDNUT
OLDFORDNUT's Avatar
the old ford 6cylinders sound like a v8 with a twin system yet holden red and blue and black 6 cylinders never do,i always put it down to the stroke length as i could not think of any other difference as we all used the same 3 or 4 muffler types back in the 80's.
funny thing is an old hot Holden grey motor with cast iron headers and a twin system made a lot of the v8 guys want me to lift the bonnet as it sounded like an 8 when going past on the hiway.
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 10:08 AM   #14
gozza
gozza's Avatar
my mate had a vh 6 cyl
slow as all buggery but it sounded like a v8
best sounding thing ive heard
gozza is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 10:09 AM   #15
BlackLS
Unmuffled modern i6s sound like a truck at low rpm under load... There could be a way to modify the exhaust headers and lengthen some cylinder's headers so it sounds like a V8?
Old 23-12-2005, 10:46 AM   #16
klawsterfobik
its not hard to get a 6 to sound like an 8, until of course you get higher up in the revrange.
Reading back through my original post, it doesnt make sense. And Raptor has pictures!
XY Wagon - NAKED!
Old 23-12-2005, 11:24 AM   #17
Steffo
LPG > You
Steffo's Avatar
You can get a 6cyl sounding pretty close. Where my best mate used to go to school, one of the guys there had an AU XR6-VCT ute, it sounded like a V8. It sounded awesome.
Old 23-12-2005, 11:36 AM   #18
Ryan
I've heard alot of 202s that sound like 8s and even a few RB30 VLs.
But for some reason ive never heard a V6 Commy sound like a 8.
I know for a fact that my dad's uncle's I6 XD bushbasher with no exhaust sounds like a 351. :hihi:
Even my VL sounds a bit like a 8 because of it lumpy exhaust note.
Ryan is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 12:11 PM   #19
XRated
Shoot.
XRated's Avatar
The note on my I6 is really thick and deep, I've had plenty of people ask if "it's a V8?" I know nothing can imitate a real V8 though..... I'll try and get a recording of my note.
20V Turbo
Old 23-12-2005, 04:28 PM   #20
Hunter
Ex EL Falcon
Hunter's Avatar
My cousin's XY with non-crossflow 250 6 in it idles so lumpy that it really does sound like a V8. So much so that the car nut mate of his down the road whos bigtime into valiants asked him what V8 he had under the hood when he first heard it.
Old 23-12-2005, 04:46 PM   #21
BlackLS
Is the same prinicpal for the sound the same for a boxer engine like a WRX?
If you want to make a 4 cylinder sound like a WRX, take out a spark plug lead.
Old 23-12-2005, 06:26 PM   #22
rob_liss_lms10
rob_liss_lms10's Avatar
quoting Hunter "My cousin's XY with non-crossflow 250 6 in it idles so lumpy that it really does sound like a V8"
the pre crossflow 6's imo are the only 6 that can come anywhere close to the sound of a V8.How-ever,in saying that....a 6 is a 6,a 8 is a 8.if you want the sound of a 8 that bad,get 1.
Red bull gives you wings?: nahhh.... we got our wings from TICKFORD
rob_liss_lms10 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 07:02 PM   #23
Ryan
Yep I agree.
While alot of 6s do sound tough like V8s their still 6 cylinders,if you want the genuine V8 rumble then buy a V8.
Old 23-12-2005, 07:13 PM   #24
smoo
smoo's Avatar
Hmm I dunno. A few 265 Valiants come close from what I've heard. But yea, a V8 is a V8, even an old original '34 Ford Coupe will tell ya that, or an LS1, even if it does need the revs piled on haha. Most Subarus have aftermarket exhausts which make them louder, drifting away from the similar sound to a V8 (less appealing imo, a stock one sounds much better)
smoo is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 07:50 PM   #25
buickman
buickman
buickman's Avatar
Have to agree with you there the log type Ford 6 from XK-XB with twin extractor system would be the closest I've ever heard to sounding like a V8.
The X/flows & ohc & any other 6 still sound like a six to me. Having always owned a V8 cars and still do as a hobby car I can pick the sound easy
Old 23-12-2005, 08:10 PM   #26
gtfpv
GT
gtfpv's Avatar
thanks to all who replied . i think i now have some idea . just read in wheels also that the boss verses the ls2 sound vastly differant due to log stroke verses short stroke and differant firing order . obviously it is just not one factor but i geuss the 8 cylinders harmonics are a base to start from. cheers.
Old 23-12-2005, 08:48 PM   #27
chippa6
Novice Professional
chippa6's Avatar
personally I don't I have heard any 6 cyl that could pass for an eight. I had a six in my xb then slotted an eight in an there was no way you could mistake it. some crossflow motors can get a nice burble at idle butstill not the same as an eight.
2001 AU XR6 - Narooma, Aunger CAI, K&N, Kings S/Low, Extractors & Exhaust.
chippa6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 09:58 PM   #28
Cheap AU
Column Shiftin'
what is the ideal set up to get the best note exhaust wise from i6 AU? out of 2 1/2 sport system straight through, 2 3/4 or 3 inch
does it sound better as they get bigger or does it tend to start to drone out n sound crap
Cheap AU is offline   Reply With Quote Multi-Quote with this Post
Old 23-12-2005, 10:08 PM   #29
stockstandard
I have to laugh at all these "my/mates 6 sounds just like an 8" comments. Anyone who knows anything about cars can pick the difference in 0.1s
Originally Posted by casper
Old 23-12-2005, 10:10 PM   #30
Casper
Contributing Member
Casper's Avatar
Normally I'd agree with you except I've been fooled a couple times myself with some of the older I6 engines.
