Old 24-12-2005, 08:53 AM   #1
BABOSS
BABOSS's Avatar
Default What's the diff?
Hi there,
We all know what a diff is and does but my question is what benifits do you get from changing a stock LSD to a 3.45? And what LSD does a stock EF come with, or does it vary?
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 09:02 AM   #2
vegabass
BASS ON BOARD!
vegabass's Avatar
Standard Falcons dont come with a Limited Slip Diff, only XR's fairlanes etc(i think you could option it)
the advantage is that instead of getting all the power to 1 wheel the lsd will provide power to both. the 3:4:5 gears in them are shorter than standard gears making engine rev through the rev range quicker but the top speed is slightly lower. (with long gears you need lots of power)
I hope this helps
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 09:06 AM   #3
BABOSS
BABOSS's Avatar
So you're saying that the benefits are acceleration, are there any others?
Old 24-12-2005, 09:16 AM   #4
niko
likes falcon's
niko's Avatar
improved performance off the line and between gears with abit more kik with the same drive train setup!
www.carhubsales.com.au
Old 24-12-2005, 09:19 AM   #5
BABOSS
BABOSS's Avatar
Cool, thanks for the info. Is it worth the money @ over $500?
Old 24-12-2005, 09:22 AM   #6
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Originally Posted by FlasherEF
Hi there,
Your "stock" LSD diff (if fitted) would be most likely 3.23 to 1 (at least that's what was fitted as an option to my EF 6, the V8 is probably different again.) I think only XR6 / 8 were fitted with 3.45, or maybe it was just the XR6 ?
The 3.45 gives a little more urge off the line, and in gear acceleration is also obviously improved due to the engine spinning a couple of hundred rpm more at any given road speed.
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 09:35 AM   #7
jonbays
TL40 Wagon?
In E-A series falcons the base sedans usually came with 3.08 Single spinner diffs with the heavier fairmonts and wagons getting 3.23 SS or optional 3.23 LSD. the XR's and fairmont gihias had the 3.45 LSD.
The higher ratio lower diff helped improve the acceleration and around town pick up of the heavier models. the LSD juts gives improved traction mostly in powering out of corners where the SS diff could stupidly spin with modest power application.
Most Auto falcons will really benefit from a 3.73 to 3.9 diff for maximum street performance but they become busy or noisy on the freeway and will use more fuel.
Old 24-12-2005, 12:58 PM   #8
MADED-6
MADED.6
MADED-6's Avatar
sorry to butt in here but i have a ed ghia as u may tell from my name and i got told it has 3:27 lsd so are u saying its actually 3:45.
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 01:04 PM   #9
Psycho Chicken
Psycho Chicken's Avatar
ED Ghia will most likely be 3.27:1. EF2 and EL Ghias got XR6 drivelive, meaning 3.45:1 LSD.
Old 24-12-2005, 04:34 PM   #10
UNR8D
FORMER T3 OWNER
UNR8D's Avatar
fairmont ghia's not fairlane ghia's get the 3.45LSD i have a 3.27SS in an NL 98' fairlane ghia.
Mischief.TV
you can sleep in your car, but you cant drift your house...
UNR8D is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 05:03 PM   #11
EDXR6T
ED ghia's have 3.27lsd's i know mine does but it ss some time's thanks to warn cones:P
i recon the 3.27 are probally one of the best gears out ther for modest streat driving i recon ther the better fuel saver gear's (and thats my consern right know)
i know ive started somthing hear with the ppl that have changed to 3.45 lol:S
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 05:16 PM   #12
XR Martin
XR Martin's Avatar
Id be surprised if the was a noticable difference in economy between 3.27 and 3.45.
2004 BA wagon RTV project.
Old 24-12-2005, 05:21 PM   #13
EDXR6T
ther'd have to be some kind of saving thear
i wunted to change to 3.45lsd and i was told it would run down the fuel gauge a lot quiker so i deside'd not to bother and i'l just get mine recoed next year
Old 24-12-2005, 05:41 PM   #14
EFFalcon
Last warning
EFFalcon's Avatar
LSD gives a nice push through the corners too.
deffinately one mod i'm glad i did.
better striaght line performance and better handling.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 24-12-2005, 08:00 PM   #15
Kenaz
Kenaz's Avatar
I love my 3.45:1 LSD!!!1!!
Taking off sideways is fun
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2005, 08:06 PM   #16
Psycho Chicken
Yeah, should of pointed that. Fairlane Ghias are all 3.27, unless it's a Sportsman or FBT (Concord maybe?). Mine's 3.27.
Old 24-12-2005, 08:07 PM   #17
EFFalcon
Last warning
EFFalcon's Avatar
yeah i think concorde's got 3.45's
Old 24-12-2005, 09:00 PM   #18
XR Martin
XR Martin's Avatar
There would probably be 300rpm difference at highway speeds. I imagine state of tune, fuel quality, tyres, ride height would make a bigger difference in economy.
Old 24-12-2005, 09:16 PM   #19
XR Martin
XR Martin's Avatar
Just put the info into a gear calculator
With 3.45 doing 70mph (112.7kmh) you'd be doing 2300rpm
With 3.27 doing 70mph (112.7kmh) you'd be doing 2200rpm
With 3.08 doing 70mph (112.7kmh) you'd be doing 2066rpm
Old 24-12-2005, 11:33 PM   #20
mcflux
mcflux's Avatar
3.27 --> 4.11 ratio change increased my rpm by 450rpm at 100kph
Gives WAY more oomph off the line, but you lose a little at highway speeds when planting it to overtake (dropping only to 3rd, rather than back to 2nd).
I see diffs as being related to cams. The diff increases or decreases the speed at which your car is most responsive. For example, someone's car's sweet spot might be 2nd gear, 40kph--->80kph. Swapping the diff might change that to 30--->65kph, or (if you went a 2.77 for some reason) 50kph--->95kph.
Whereas the engine's rpm "sweet spot" might be 1500-4000rpm with a standard cam (or cams), but a performance cam might alter this to 1500-5500rpm.
I love engine/drivetrain mods
