Hi All
Ive removed all the screws from the drivers side trim,of EF but it still won't lift off, anyone know what I could be doing wrong. thanks guys. |
they call me Tibbo
have you got the door handle out?
Have you removed the tibbe lock button?
Theres usually a screw in the door handle i think.. and then you have to kinda twist it off this smally rod, which opens the door.. You might also wanna remove the side mirror adjusting buttons. Once all the screws are out, you have to push the door trim bit more from the bottom, because i think it locks in at the top.. Hope that helps
