Old 28-12-2005, 02:28 PM   #1
The Taipan
The Taipan's Avatar
Default Idle? or Off?
OK, at the lights its clear, leave it in "D" or knock it out of gear, and
leave it running, if an emergency vehicle needs you out of the way you can
move, and its safer for all.
But my question relates more to a fuel usage vs. engine wear/heat problem.
Apparently you use more energy idling for more than 30 seconds than you do
stopping the engine and restarting again... that's fine I can accept that as
possibly being true, and started using it in places where it was safe to
shut down - eg macca's drive thru where you always have at least 2-3 mins
wait... but while waiting for my mcJack's Fried Chicken once I got to
thinking about heat soak, while the engine is running so is the coolant,
therefore oil temps stay stable, shortly after an engine is shut down, often
the oil temps rise due to heat soak, that would probably be OK if the engine
stayed shut down, but if you plan on starting shortly afterward would
certainly take much longer to cool off again...
After pondering this for a while, I decided to switch to thinking about
world peace and ask my expert friends on the internet... which is going to
protect my engine for the longest and possibly save fuel?
The Taipan is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 02:54 PM   #2
Mr. CVE
If it aint Blown it Sucks
Mr. CVE's Avatar
Umm,
My head hurts thinking about it.
Especially if your starter motor is a bit average.
Australia's fastest 3V n/a Ghia 13.52 @ 102 mph
@235 rwkw !!
Now turbo 11.77 @114 mph
320 rwkw, 810 nm torque, 280rwkw @3000 rpm !! :thebirds:
Now for sale
http://www.fordforums.com.au/showthread.php?t=11296772
Thanks to Snort Performance, Headsex and CVE
Street car DeTomaso Pantera
Drag car 1995 Mustang, Haleys Comet ( It's back !)
Power by CVE
Melbourne's first SNIPER Tuner :
Now tuning E series
Mr. CVE is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 02:56 PM   #3
pauljh74
pauljh74's Avatar
I'd say leaving it idling is better, then there's less strain on the starter motor and battery - If we're talking about a minute or so. Consider taxis do lots of Ks because they are running alot. In summer the heat soak can be alarming when you switch it back on after 5 mins and the temp gauge has shot up 50%, but it comes back down quickly as the hotter coolant is cycled through.
In the end you might use a little more fuel, but wear and tear on other parts will be reduced. 3 mins plus at Maccas - better to shut it off
Originally Posted by Mark Webber
Not bad for a #2 driver
Mark Webber after winning the 2010 British Grand Prix.
pauljh74 is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 02:59 PM   #4
Steffo
LPG > You
Steffo's Avatar
You'd be surprised how much fuel it takes to start an engine.
Plus starter motors and batteries are not cheap items to replace.
Leave the engine running. It's better for it.
Old 28-12-2005, 05:08 PM   #5
LTDHO
The one and only
LTDHO's Avatar
I'd leave it running and in gear always at the lights. If I have to wait a long time at Maccas, then I'll switch it off.
Most cars runn all injectors on startup only so you use more fuel, plus the battary has to be charged, so fuel is used.
So unless your temp is very high, leave it running the heat soak will disapear once you are moving.
Tuned by CVE Performance
Old 28-12-2005, 07:05 PM   #6
ltd
Force Fed Fords
ltd's Avatar
Leave it running.
This is for several reasons
1/ No heat soak unless your vehicle has a problem and the temperature is going up.
2/ No heat soak to the gaskets causing them to vulcanise and leak sooner
3/ Constant oil pressure providing much less wear (see a taxi)
4/ No startup wear due to minimal oil temp and pressure
5/ Less chance of a sudden cooling system failure due to spiking temperatures after shut down, as well as increased pressure from said rising temperatures.
6/ Less component wear due to less use (battery/starter)
7/ Less chance of any type of failure for any of the problems listed above.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley
Powered by GE
ltd is offline   Reply With Quote Multi-Quote with this Post
Old 28-12-2005, 07:35 PM   #7
Mechan1k
Mechan1k's Avatar
Originally Posted by ltd
Leave it running.
Couldn't have said it better myself ... although I do knock it out of "D" at lights though ... a little less stress on the gearbox I find ... and less fuel used as well (hardly notice it though .... but it makes a difference for me).
Old 28-12-2005, 07:44 PM   #8
JC
JC's Avatar
What about those new cars that automatically switch off at the lights, and then restart just be pressing the accelerator. I wonder if I can mod the AU to do that?
Ford Performance Club ACT
Old 28-12-2005, 08:25 PM   #9
The Taipan
The Taipan's Avatar
Thanks guys, now back to the problem of world peace...
Old 28-12-2005, 10:05 PM   #10
Mechan1k
Mechan1k's Avatar
Isn't that on the electric/hybrid cars to save battery usage to get further distance out of the batteries????
Old 28-12-2005, 10:56 PM   #11
Biggoggs
Rider on the storm
I'd personally put in in D, then if someone rams the back of you, you don't roll into traffic. My driving instructor taught me to put the handbrake on at traffic lights, but the Falcon's umbrella-brake becomes a nuisance.
Biggoggs is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 07:17 AM   #12
LTDHO
The one and only
LTDHO's Avatar
It'll never happen, not in a million years. Stick to what can be helped.
I was taught the opposite and I think it is illegal too.
Old 29-12-2005, 11:19 AM   #13
megsy
Undergraduate EB Operator
megsy's Avatar
i only knock it ouy of drive if im waiting for a goods train ( you know those 2 KM long buggers) then it's in park not in nuteral but i never turn her off (see formentioned reasons)
Simon
04 BA Xr6 ... now with carpark dints
megsy is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 03:32 PM   #14
Biggoggs
Rider on the storm
Why were you taught the opposite? But illegal? Rubbish.
Old 29-12-2005, 04:46 PM   #15
ltd
Force Fed Fords
ltd's Avatar
Me too. And you're absolutley correct about less wear on the gearbox. For the non believers, do 10000klms with the tranny in N or P at the lights, then do a fluid change. Now do the same klms with it in D and do a fluid change. Notice the difference in colour.
A mate who works for Holden in Adelaide told me that the climate is so hot and dry in summer down there that they have many commodores coming in with fried tranny's, and heaps of them on tow trucks because they blow their seals due to increased pressures and temperature when sitting at lights in D with the aircon on on a hot day. Problem is they develop so much fluid pressure that they get extreme temperatures and pop the main seal. Also they suffer from torque convertor problems for the same reasons but we don't need to go into that now. He said that their service managers advise customers to pop them into P or N when idling at the lights with the aircon on.
Powered by GE
Old 29-12-2005, 04:49 PM   #16
vztrt
IWCMOGTVM Club Supporter
vztrt's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: vztrt is one of the most consistent and respected contributors to AFF, I have found his contributions are most useful to discussion as well as answering members queries.
Wouldn't that be a problem with the Ford tranny's as well??
vztrt is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 06:11 PM   #17
Aussie_Geo
Aussie_Geo
Just another reason to go the manual :hihi:
wow that will throw a cat amoungst the pigeons.
cheers
Peter
: Velocity Typhoon :
:sm_headba 366 rwkw 770 Nm Xtreme Tuned and Nizpro Stage 2 :sm_headba
WARNING! Highly Addictive
Aussie_Geo is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 06:17 PM   #18
4.9 EF Futura
Official AFF conservative
4.9 EF Futura's Avatar
No problems as of yet! Yeah, i tend to go to N at the lights but never turn the engine off.
Just pay attention coz these engines take forever to rev down from 3000rpm, lol.
A cup half empty... but full of euphoria.
4.9 EF Futura is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 12:38 AM   #19
ltd
Force Fed Fords
ltd's Avatar
No, apparently they have a different pump, as well as having a more sophisticated valve body/solenoid arrangement. Fords old 3 speed did however suffer similar problems. Also, ford started fitting seperate transmission coolers as standard to the range from EF onwards whereas previously, they relied upon the engine radiator to do the job. In actual fact, on the EA2 to the ED the four speed had problems with fluid temperature on hot days, and the units would often go into limphome mode (locking it into 3rd gear) until the radiator could cool the fluid sufficiently ie not sitting in traffic.
Powered by GE
Old 30-12-2005, 12:43 AM   #20
ltd
Force Fed Fords
ltd's Avatar
And before this gets too far, by pump I mean impeller.
So at idle the ford box has lower fluid pressure than the holden box at idle.
This is not to start a holden/ford bashing thing; it's just reliable information from some tech guys in Adelaide, and I must admit on those really hot days I have seen a few dump their fluid. But I emphasise that it is not all of them, just some and that is more a result of contaminents in the fluid, or blocked filter screens, or general condition of the unit. Out of the box they didn't do it as far as I know.
Powered by GE
Old 01-01-2006, 07:17 PM   #21
mcflux
mcflux's Avatar
How does one do 10,000kms when stationary?
Old 01-01-2006, 07:26 PM   #22
FordFan86
meow
FordFan86's Avatar
I was thinking the same thing. Ghastly business this is.
Unless it was on a runway, trying to gain lift? But the road was able to go the other way, at the same speed? Would the car be moving then or not?
FordFan86 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2006, 08:44 PM   #23
NZ
NZ's Avatar
He means compare 10k orth of driving not using N at the lights but leaving it in D and then compare 10k putting it into N
Old 02-01-2006, 12:29 AM   #24
geckoGT
Ich bin ein auslander
geckoGT's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always level headed and i notice him being the voice of reason when a thread may be getting heated
No driver of an emergency vehicle will get upset at the 5 seconds it takes for you to drop it in drive, just happy that you have seen them. As for the park brake, on my advanced courses and emergency courses we were told keep your foot on the brake, that way you have 4 wheels braked instead of 2, lot more effective.
Growing old is compulsory, growing up is optional!
geckoGT is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 08:59 AM   #25
Mechan1k
Mechan1k's Avatar
I select D before the lights change .... I am ready for it.
Mind you ... with the amount of kms I do ... I am used to dropping it out of gear.
cheers
Peter
I'd love to be manual ... but being a courier in Sydney ... and also towing ... the manual/clutch setup is weak really.
Mind you ... the manual gearbox can only handles 1200kg towing ... the auto can take 2300kg ... that's why for the first time in 11 years I chose an auto.
Auto is safer to tow with ... especially with the newer SSS boxes as well.
