Old 06-01-2006, 09:19 PM   #1
frtmatt83
ANOTHER FORD DRIVER
Default locks
just a question I have a ea ford fairmont i want to change the door locks and ignition. I have currently the old xf style of keys which i want to upgrade to the ea eb type of keys. I know the door loocks are a straight swap what would i have to change of the ignition. i have a cfi engine.
any help please
matt
frtmatt83 is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 09:21 PM   #2
gthofan
Gunna girlie-man
gthofan's Avatar
do you mean the tibbe locks, the different style of key??
WADE CAMS-- UNLEASH THE POWER!!
<INSERT WITTY SIGNATURE HERE>
Daily- 05' BA futura... work done.
Cruiser- 85' VK berlina... more work done
gthofan is offline   Reply With Quote Multi-Quote with this Post
Old 06-01-2006, 09:40 PM   #3
frtmatt83
ANOTHER FORD DRIVER
no i don't have central locking the locks are the xf style i guess. i want to change the ignition do i need to change of whole ignition stuff or is it just the part the key goes in
matt
Old 07-01-2006, 08:09 PM   #4
frtmatt83
ANOTHER FORD DRIVER
does anyone know if i can swap the ignitions over
matt
Old 07-01-2006, 10:03 PM   #5
EDXR6T
yer im pritty sure it's go to the wreak and pick up a ignition barrle
but ther might b somthing with the cfi and mpi somthing to do with the fuel pump
but im not 100% so if n e one can correct me
cheers
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2006, 01:14 PM   #6
TwistedEL
TwistedEL's Avatar
I did this in my EA back in the day. Just remove the old barrel and replace it with the new one. IIRC it is a bit fiddly to do. Can't remember how I did it exactly.
Old 08-01-2006, 02:48 PM   #7
frtmatt83
ANOTHER FORD DRIVER
what is the IIRC. can anyone tell me how to do it please
matt
Old 08-01-2006, 10:21 PM   #8
frtmatt83
ANOTHER FORD DRIVER
matt
I've been told since the are both ea that there should be no problem it should be a case of plug and play. Also i have seen cfi engines with the ea to ed style key. Can anyone confirm if it is plug and play
any help
matt
Old 09-01-2006, 12:04 AM   #9
TwistedEL
TwistedEL's Avatar
IIRC = if i recall correctly.
You only replace the barrel - it's one unit, not the entire ignition, switch and all
There are no electrics involved. You will need to have the old key in the ignition to do it - it can't be removed while in the OFF position.
Once again I can't remember specific details.
The door & boot locks are held in with a clip and easily replaced.
Old 09-01-2006, 10:10 AM   #10
Steve D
Irregular Member
Steve D's Avatar
To remove the barrel from the inbition lock, insert the key, turn it to the accessory position and press the small button on the side of the ignition lock to release the barrel. You'll need a pen tip or a small screwdriver to press the button.
I'm not certain if an XF barrel has identical dimensions to the later ones, though.
She mostly takes : Ford Territory TX AWD (SY 2006)
*** Wheels magazine COTY 2004 ***
I usually get: Mitsubishi Magna ES (TL 2004)
*** Wheels magazine COTY 1996 ***
Steve D is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 11:47 AM   #11
naughtyfalcon
i did this last year and you need to replace the whole ignition switch,,the barrel won't go in,,the raised part of the barrel that goes into the switch is to big..
2000 AU Wagon
naughtyfalcon is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 01:05 PM   #12
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
You CANT just swap over the barrels, the whole ignition and steering lock assemblies must be changed, the actual ignition switch does not need to be changed.
go to a wrecker and buy a ignition assembly, but the actual switch will fit in behind it...
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 09-01-2006, 03:00 PM   #13
frtmatt83
ANOTHER FORD DRIVER
so basic there is no point really changing for the xf style key to ea or eb style key without having to rip a lot of things a part is that correct
matt
Old 09-01-2006, 03:43 PM   #14
santoitaliano
BF F6, APV SR3900
na pretty easy...
for ignition:
take off bottom plastic cover under steering column, then undo the two break-nuts (will need to probably hammer off with a screwdriver), get two new break-nuts and a steering lock assembly (from pick a part cost me $10 without cylinder), put it in place and put in new break-bolts
for doors (fronts only):
take off door trims, disconnect locking bars and remove circlip, lock will pop out, put in new lock...
for boot:
remove garnish, disconnect locking bars and remove circlip and pop out old lock and put in new lock.....
pretty easy on the whole...
Santo
Daily:
Bluepower enhanced.
Old 09-01-2006, 07:22 PM   #15
frtmatt83
ANOTHER FORD DRIVER
would anyone have a pic of the steering lock assembly so i know what to look for at the wreckers
matt
Old 10-01-2006, 10:55 AM   #16
frtmatt83
ANOTHER FORD DRIVER
Is this what i need
matt
Old 10-01-2006, 11:38 AM   #17
naughtyfalcon
a wrecker will only sell the unit as a whole,,it will just wire up anyway,,i have one with the smartlock cable on it,it's just don't get used.
and why has my signature dissapeared?
2000 AU Wagon
Old 10-01-2006, 12:59 PM   #18
santoitaliano
BF F6, APV SR3900
thats the one... ;)
Santo
Daily:
Bluepower enhanced.
Old 10-01-2006, 05:04 PM   #19
frtmatt83
ANOTHER FORD DRIVER
is that whole unit or from the lock assy to the lock cylinder
matt
Old 11-01-2006, 12:45 AM   #20
santoitaliano
BF F6, APV SR3900
you need:
1 x lock assemmly
1x shear bolt
1 x ignition cylinder
Santo
Daily:
Bluepower enhanced.
Old 12-01-2006, 08:57 PM   #21
frtmatt83
ANOTHER FORD DRIVER
I rang around some wreckers today and managed to get a someone that has the full ignition setup and locks. The only the key and igniton is one from a smart lock setup would the ignition be able to go in my car cfi. Can anyone confirm this please
any help
matt
Old 13-01-2006, 04:06 PM   #22
frtmatt83
ANOTHER FORD DRIVER
can anyone confirm the would still work if i put the smartlock ignition setup in my car. My car doesn't have smartlock
matt
Old 15-01-2006, 06:13 PM   #23
jedaarr
jedaarr's Avatar
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
I have a smart lock ignition in my car it
works no problem as the wiring is not
connected & there is no female to connect it
to as it does not exit, it works no problem at all.
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD.
TO MANY YEARS IN THE MAKING : :1syellow1
jedaarr is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2006, 09:02 PM   #24
snypereb
[EBGLT]
snypereb's Avatar
How did ya go with all this mate? How much did it end up setting you back?
[EBGLT]
Old 15-01-2006, 09:09 PM   #25
frtmatt83
ANOTHER FORD DRIVER
didn't work out but i been told by a wreckers where i get most of my parts from.. $55 does includes everything i need
matt
