Old 21-01-2006, 10:33 PM   #1
NARCEA
5/00 AUII Forte
Default Faulty fuel sender?
Hi guys.
AUII Forte.
Switch her on fuel guage shows full. 10 seconds later, drops straight to empty. DTE displays 479, and no fuel warning beeps or light.
Any ideas besides a faulty fuel sender, only other one I can think of is float not free to move as it is been in a prang, however fuel tank not damaged.
Could it just be low on fuel.... and DTE a result of battery being disconnected??
Any pointers shout out, otherwise I'll probably fiddle tomorrow and Monday.
Cheers,
ian
05/00 AUII Forte
NARCEA is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 10:40 AM   #2
AUXRVIII
This fault is usually related to a higher than normal resistance in the fuel sender which means it will have to be replaced or an open circuit in the wiring. Check the connecter at the tank for corrosion or backed out terminals. Sedans weren't common for having sulfur affected senders.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 11:14 AM   #3
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
mmm, I would say prob, a short somewhere as a dead sender unit wouldn't first say full. Check your wiring for the sender and also check your fuses too - can't hurt.
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 12:07 PM   #4
AUXRVIII
The cluster guage goes to full then to empty when there is a high resistance, this can be caused by sulfur build up of the sender, very common on AU/BA wagon & ute & also LR Focus. The fault can be reproduced by using a resistor wheel, when too much resistance is dialled up the guage will go to full then back to empty.
Old 22-01-2006, 01:40 PM   #5
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
This happened in my EA, fuel guage rose to full then dropped straight back to empty, replaced the sender unit and it was all good, there was no corrosion on it, it was just old and it wasnt touching the contacts properly any more.
bender
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 01:58 PM   #6
NARCEA
5/00 AUII Forte
thanks for the input guys i'll let you know what it turns out to be when i start to fiddle.
ian
05/00 AUII Forte
Old 24-01-2006, 02:47 AM   #7
V8falcons
V8falcons's Avatar
My au2 wagon SR does the same thing when I fill it up after about 50ks it goes back to full.
V8falcons is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 08:02 PM   #8
NARCEA
5/00 AUII Forte
Can someone tell me what fuses to check for what I've described above? I didn't get the handbook with the car, save me pulling them all out. I'm getting stumped with this problem. The car seems to be able to tell when the sender is not plugged in because it will crank but not start. Anyone also able to help me with a wiring diagram for it so I can have some fun and work backwards.
Cheers,
ian
05/00 AUII Forte
Old 08-02-2006, 09:14 PM   #9
AUXRVIII
Cheers,
ian
If your disconnecting the sender at the tank you will also be disconnecting the fuel pump, this is why it won't start.
Old 08-02-2006, 09:15 PM   #10
NARCEA
5/00 AUII Forte
well that makes sense.... haha
can you shed any light on which fuse I should be looking for?
05/00 AUII Forte
Old 08-02-2006, 09:20 PM   #11
AUXRVIII
Forget about the fuses, refer back to my first post.
Old 08-02-2006, 09:36 PM   #12
NARCEA
5/00 AUII Forte
the male and female connector and plug are spotless, i've dabbed both with some crc but to no avail.
05/00 AUII Forte
Old 08-02-2006, 09:49 PM   #13
AUXRVIII
It was common for the senders to have a layer of sulphur build up on the sender contacts, thats why I mentioned it may have to be replaced, if no faults are found with the wiring.
Old 08-02-2006, 10:10 PM   #14
NARCEA
5/00 AUII Forte
yah i'm going to try fuses, then sender (donor taxi may help with this), then as a last resort wiring. cheers for your help.
ian
05/00 AUII Forte
Old 26-03-2006, 01:44 PM   #15
NARCEA
5/00 AUII Forte
SOLUTION (finally got around to having it looked at): completely f ked fuel sender unit. It had twisted and wrapped around itself, and was making a poor contact.
COST TO FIX: 215 bucks at autoelectrician
cheers,
ian
05/00 AUII Forte
Old 26-03-2006, 08:37 PM   #16
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
Good to hear you got it fixed mate
