Old 22-01-2006, 04:39 PM   #1
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
Default Alternator
Hey Guy's
I have an EB and i think my alternator is too small, i have a powerful sound system and when driving the head lights dull every time a beat comes, i am told it is a 85 Amp lternator, and that the EL's Have a better alternator of 108 Amp's, is this true and will it bold on if i can get one.?
VE SS Ute manual 09
AU XR8 UTE 200KW manual 02
Challanger Ski boat V8 01
125 Thumpster 2010
Swag
All set for the weekend
eb91xr6 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 04:51 PM   #2
opto
Yes it will bolt on but you have to grind a little of the alternator housing to suit the upper bracket and find a 10 mm longer bolt and nut for the upper bracket and carefully grind a section of the top bracket where the nut passes. you also need a new larger belt Bosch 3PK995 by memory.
Done it, works fine on an ED, same as an EB.
opto is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 05:20 PM   #3
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
thanx if i went to a wrekers and riped one of an EF would there be any problems
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 22-01-2006, 05:35 PM   #4
John_LS1
i dont think that will work to well, people have tried to do this without going the whole EF/EL setup and have had problems with the belt slipping. the EA-ED belts are way to thin for a 110 amp altenator.
Old 22-01-2006, 05:40 PM   #5
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
can i just swap the pullys form an EL then
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 22-01-2006, 09:18 PM   #6
fairmont1998
fairmont1998's Avatar
No, the EL has a serpintine, micro V belt. Totally different to the classic V belt on the ED
Current Rides:
2012 KK Jeep Cherokee Limited CRD - Still going strong
2019 MG ZS Essence
1988 RD Mitsubishi Colt GL - 59kW of Fury
2022 Kia Stinger GT
fairmont1998 is offline   Reply With Quote Multi-Quote with this Post
Old 22-01-2006, 09:41 PM   #7
5L
[ 5L ]
5L's Avatar
just buy a capacitator that hooks up in between the battery and the amp, it stores power and dont put as much stress on the battery, and there like 100 bucks
www.ignitionimages.com
Old 22-01-2006, 10:02 PM   #8
Brent79
V belt on ED? My EB doesnt have a V belt? I think u'll find that was only pre EB cars.
Ive got an EF+ 110A alternator and it works great! no belt slip at all! Opto is correct when he says u need to file out the bracket and use a different bolt.
Brent
EB1 Falcon Wagon
3.9L Multipoint with 5 speed manual
Pacemaker extractors & 2.5" Redback exhaust
Tickford Head and Wade 1004 cam
HP4 Chiptorque chip and XH intake
1992 DC LTD
5LTR DUEL FUEL
Brent79 is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 06:43 PM   #9
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
having a bigger Alternator will that take power out of the motor or will it run the same as the old one
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 30-01-2006, 09:09 PM   #10
snypereb
[EBGLT]
snypereb's Avatar
I have a practically brand new capacitor you can have for $100
[EBGLT]
Old 31-01-2006, 01:39 AM   #11
Brent79
well considering the laws of physics regarding energy in a closed system, id have to say yes it will take more power from the motor (slightly more magnetic resistance) but u wouldnt even notice it.
Brent
EB1 Falcon Wagon
1992 DC LTD
5LTR DUEL FUEL
Old 31-01-2006, 02:30 AM   #12
santoitaliano
BF F6, APV SR3900
santoitaliano's Avatar
how good is your battery? im running a 85 or 95 amp alt with a decent system (~710wrms) and dont get any dimming?
Santo
White APV SR3900 [WIZZRD] (Click Here) [/COLOR]
Daily:
2006 Red BF F6 Typhoon
Bluepower enhanced.
santoitaliano is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 02:34 AM   #13
XR Martin
XR Martin's Avatar
So you can use an EF/EL alternator without even swapping the pully?
2004 BA wagon RTV project.
Old 31-01-2006, 02:51 AM   #14
Brent79
Correct.
Brent
EB1 Falcon Wagon
1992 DC LTD
5LTR DUEL FUEL
Old 31-01-2006, 07:00 AM   #15
EDXR6T
yer im running a pritty hard core sreza and i only get a little dim wen turn up to the max
but thats with no engine runing just get a cap a bit less f@#$ around and it will look cool
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 05:30 PM   #16
santoitaliano
BF F6, APV SR3900
lmao... if its dimming with no engine on it has NOTHING whatsoever to do with your alternator size... only if it were doing it when the car was on... bigger alternator will achieve nothing
Santo
Daily:
Bluepower enhanced.
Old 31-01-2006, 06:12 PM   #17
Simmo
White Lightning
Simmo's Avatar
slightly off topic, but at night with my lights on and a very light sound system [no subs], when i put my indicator on the volt meter will drop almost 1 whole bar. its a lot of movement of the needle i thought. im sure my alternator is from factory.
Simmo is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2006, 09:40 PM   #18
eb91xr6
V8 Ute V8 Boat
eb91xr6's Avatar
its ok when im driving its just when im sitting at the lights with the motor running, would a capacitator stop this
VE SS Ute manual 09
125 Thumpster 2010
Swag
Old 31-01-2006, 10:17 PM   #19
santoitaliano
BF F6, APV SR3900
not sure.. no experience with caps.. i do know that on caraudioaustralia they tested caps and spl output and in all cases they registered a higher spl reading without the cap that with it... on the other hand they reckon a 1 farad cap per 1000wRMS of power... i reckon your best bet would be to get a bigger battery, with a higher reserve capacity. if your battery wasnt charging you wouldnt be able to start it... for around 100-120 bucks i reckon go for a new battery... check out marine batterys which have a much higher capacity and are built much more solid than car batterys..
Santo
Daily:
Bluepower enhanced.
