Can someone please tell me the difference between psi and bar. What is 6psi in Bar pressure?
V8 Turbo Hoon
1 bar = 14.7psi so 6psi is about 0.4-0.5 bar
Gunna girlie-man
i think i found it here mate. hope it helps
http://www.britishmetrics.com/html/pis-bar.htm
WADE CAMS-- UNLEASH THE POWER!! <INSERT WITTY SIGNATURE HERE> Daily- 05' BA futura... work done. Cruiser- 85' VK berlina... more work done ![]() ![]() |
![]() Join Date: Jan 2005
Same thing, one of them is pre metric (not sure which one :P) but if you multiply bar by 14.5 you get PSi.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
Ah too late lol, is one Bar 14.7 or 14.5 PSi??
thanks for the info. I ask becasue I've been reading that stock 4L engines will take up to 12psi of boost, make 220 rwkw and give trouble free motoring for at least 30,000 kms. I'm in the process of putting a turbo on my ed, but I'm only aiming for 6 psi as a starting point. These 4L engines have so much potential, I can't wait to blow a few skylines away!!! Go the Fords!!!
Gunna girlie-man
you will mate. i think i heard u can have 7psi of boost pressure before any engine work needs to be done
Pods rule
The answer to that question is in a recent ford mag of some sort, i have the mag but i cant find the story... it also shows to change HP to KW and stuff like that
EB xr6... Now sold ![]() Check out Build- http://www.fordforums.com.au/showthread.php?p=3083422&posted=1#post3083422 Current Rides- Xf ute, just installed ea wiring loom, dashboard, 3.9lt mpfi and a 5 speed with extractors and a 2/1-2 exhaust... its much better now! Check out Build- http://www.fordforums.com.au/showthread.php?t=11288204 -BF XR6... And its BLACK! |
my reference is the "Forced Induction Handbook" by Street Fords, its on sale now.
rofl copter
a certain ea with an el motor ran a stock motor (with cam and XR springs) with a BA turbo running 10.5 seconds and its still going hard :P
GQ patrol.
.... thats all |
#11 | |||
#12 | ||
6 psi in these engines is nothing man... i have stock ecu, stock internals, stock trans.. I've had countless people telling me "ohh man you have to uprgrade this and that, your engine will never last" Im running at least 9 pound all day every day, no engine trouble's whatsoever.. I've done about 5,000kms so far.. touch wood (quarter mile time was done with 4psi)
thats good to hear, people with experience in the mod have been saying the same thing, the stock motor loves a bit of positive pressure! down the track i'll put a acl engine rebuild kit thru the motor, or something similar should I want more grunt, I've been told that once I get a taste for it, i'll want more
just a couple of questions though, when mounting the intercooler, where did you place the air con bottle at the front, back in the engine bay? is this a simple job to move? |
#14 | ||
Performance moderator
![]() Join Date: Feb 2005
They can run up to 15 Lb all day evey day..But compression an TUNE comes into it...
My car though its been built from ground up for forced induction still has black smoke from exhaust on hard throttle / boost 18 Lb..That due to SAFE tune... The boost levels people talk about is what the std map senser with read before it shuts down..Which is usually around 8 to 10 Lb..But at that level it would be runing WAY lean..Its rpm and bad tune that kills any engine...Imo an engine driven by family person up to 200.000 klrs [ serviced well!] is still o/k to turbocharge if engine is still in good nick..Though timing chain, cylinder head bolts, rear main seals should be looked at being replaced...With the extra clearance due to wear is about right for forced induction...
#15 | ||
[EBGLT]
Sunny is running 8 psi isnt he?
[EBGLT] Become an E-Series Owners Club Member Today!
http://eseries.com.au/index.php/membership/ |
