Old 30-01-2006, 09:48 AM   #1
Felony
Wherever u go there u r
Default v8 eb diff into ea, str8 fit?
Im bout to buy a 3:25 eb v8 fairmont diff, will it go str8 into my ea 6 without a hassle?
thanks
Felony is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 11:59 AM   #2
Felony
Surely someone knows and can help b4 i buy this diff?
thanks
Old 30-01-2006, 11:10 PM   #3
sam12h
Runnin C3H8 & C4H10
sam12h's Avatar
If you are fitting the whole diff i think (iirc) it should be a straight fit, since the control arms, springs, shocks, brakes etc replacement parts are all listed as fitting ea-ed.
All the V8's eb1 onwards has 28 spline axles (my eb1 V8 has 28 spline anyway), whereas the ea-eb1 6cyl had 25 spline vs eb2 onwards 28 spline. This means the guts won't swap (gears only) but i get the impression you mean the whole diff assembly.
Production Editor- Street Fords, Xtreme Fords, Aussie Brutes and Custom Utes Magazines
sam@streetfords.com
Phone: (02) 9741 3838 (direct line)
sam12h is offline   Reply With Quote Multi-Quote with this Post
Old 30-01-2006, 11:14 PM   #4
Psycho Chicken
Psycho Chicken's Avatar
Is it series one or two EB?
Old 30-01-2006, 11:25 PM   #5
Damo
it will fit but if it's a series 2 |EB diff you will need fatter (EB2 style) bushes pressed into the diff end of the lower constrol arms, or you can use metal pipe as a spacer.
Old 30-01-2006, 11:42 PM   #6
snypereb
[EBGLT]
snypereb's Avatar
Is that illegal damo?
[EBGLT]
Old 31-01-2006, 09:49 AM   #7
NZ
NZ's Avatar
dont forget to check the tailshft unit type.
Old 31-01-2006, 01:02 PM   #8
Felony
Ok thanks guys i will check that all out, and yes im looking at fitting the whole assembly disc to disc,
thanks
Old 31-01-2006, 08:05 PM   #9
sphell
sphell's Avatar
I wouldn't recommend using spacers on the lower control arms...you'll get knocking sounds around corners. Getting ED bushes will only be about 100 bux from Pedders if you pull the arms out yourself.
