Old 01-02-2006, 06:08 PM   #1
crannersEL
crannersEL's Avatar
Default Has this ever happened to you?
I put my new sub into my Falcon yesterday, and on the way home from work tonight i decided i'd crank it up a bit. Later on down the road i noticed that my interia rear view mirron had worked its way loose and was about to fall off its bracket on my front window.
If this has happened to you, what have you done to secure it back so it doesnt fall off?
Thanks Paul
crannersEL is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 06:10 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
a few ppl have actually had the whole thing fall off the window.
vibrate the adhesive loose.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 01-02-2006, 06:14 PM   #3
crannersEL
crannersEL's Avatar
So whats the answer, just re glue it on once it falls off?
Old 01-02-2006, 06:26 PM   #4
trick_xd
I build your wish list...
trick_xd's Avatar
Ha Ha Ha
yep the same thing happend to me in my old XE
and it even blew out the corner of the rear window
I reglued my mirror back on
Then 1 hot day i had it cranked right up and i seen it was comeing loose again so i grabed it and just thought that i could pull it off. I gave it a bit of a wiggle and broke the windscreen
I was so ИИИИed off then
So just be carefull
or you might do the same thing if unlucky
trick_xd is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 06:34 PM   #5
EDXR6T
yep thats happened to my mate now he drives around with no rear view mirror lol
mine vibrates is self out of wak but it isent falling off the acctule metal slug thing
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 06:39 PM   #6
FRDXR6
FRDXR6's Avatar
you can buy that mirror glue stuff from k-mart etc
FRDXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 06:40 PM   #7
niko
likes falcon's
niko's Avatar
thats never happened to one of my own cars, i hopped in an ea wagon for my mech, and i adjusted mirror for myself and it broke off ahhahahaha
ИИИИbox, it was glued in a different spot
www.carhubsales.com.au
Old 01-02-2006, 06:40 PM   #8
crannersEL
crannersEL's Avatar
But then it will work lose again, i think i might have to tone it down and not have it as loud.
Old 01-02-2006, 06:52 PM   #9
Damo
just get come of the strongest glue you can find. Not sure if araldite would work on the glass. Mine has done the same but not due to bass, it come off when i went too fast over train tracks, didn't actually come off the glass so i just slipped it back on. It fall off every now and then. Same with the fuse cover panel, that allways falls off on rough roads.
Old 01-02-2006, 06:59 PM   #10
RavenLS1
you just have adjust it fully down then angle it in to the right spot if you no what i mean.( probably not).
I have 2x 12 inch jaycar responses in my wagon and i coundnt see threw the mirror but if i adjusted it right it would stay there.
405rwhp LS1, FG XR6T Ute manual, VE series 2 Omega LPG.
RavenLS1 is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 07:02 PM   #11
crannersEL
crannersEL's Avatar
Im not too worried about it holding its viewing position, i just want the thing to stay on the windscreen. Ive put a hocky tie around it and its holder and its holding in place okay for now, a more permadent solution will have to forth come.
Old 01-02-2006, 07:41 PM   #12
5L
[ 5L ]
5L's Avatar
its just held on to the bracket with an allen jey screw, just find the right size allen key and tighten it up, mine has been fine since i tightend it, before i would crank the subs and it would drop down.
www.ignitionimages.com
Old 01-02-2006, 07:56 PM   #13
Emma
hehe, That happened to me in my eb we got this blue glue and glued it back on...as tough as tough can be now :voldar02:
Emma is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2006, 08:05 PM   #14
opto
If the mounting plate has come off the window and you want it to stay on for good, take it to a windscreen install company, let them glue it on with their commercial glue, then it should stay on.
opto is offline   Reply With Quote Multi-Quote with this Post
