Hi
i have 3 ECU sitting here just would like to know what there from its 96DA-12A650-BB 6DBB 96DA-12A650-NB 6DNB AND 96DA-12A650-JA 6DJA i tryed the E-series parts list but nothing come up thanks Nick
FG XR8, 6spd auto, dual zone, sat nav, camera, leather, k N filter, Quad exhaust. |
![]() Join Date: Dec 2004
<Friend on MSN> says:
can u post that they are all EF coil pack ecu's please <Friend on MSN> says: the end numbers have something to do with the model <Friend on MSN> says: fairmont/falcon/futura/etc Hope that helps. |
And an update:
<Friend on MSN> says: make sure you tell him they aren't tickford Dave says: ok <Friend on MSN> says: tickford ecu = 96dT <Friend on MSN> says: the T means tickford <Friend on MSN> says: A means standard |
PM me if you want
How many pins do they have EF and AU have 104 pins or so, and EL will have 60 pins for a start.
95DA FA12650 AC - XH series 1 6 cyl manual. - 60 pin plug
96DA FA12650 GC - El V8 auto with 3.23 diff ratio. This is all vehicles not including XR8 96DA FA12650 FC - EL V8 manual sedan (XR8) 96DT FA12650 BE - EL 6cyl auto with 3.08 or 3.23 diff. (GLi or Futura) 96DT FA12650 EE - EL 6 cyl LPG auto 3.08 or 3.23 diff. (sedan and wagon) 96DA FA12650 JC - EL Fairmont Ghia Auto with 3.45 diff (XR6 Spec) Copied from another of my threads. The first you have is 6cyl auto gli or futura 2nd MAY be a cop ecu, the N rings a bell as being a cop ecu for some reason The third is an EL Ghia ecu. The ECU code is as whats said above, 6DJA means Standard car, J is the model code, A is the revision level. Its interesting that in the EL Ghia's despite having the tickford engine the ECU doesnt have a 6T code. |
So yeah dave your friend on msn isnt entirely correct.
Two > One
96DA, since when did EF's run 96DA ecus........
slap your friend Dave
He wishes not to be identified, and alerted me to this thread (I wouldn't have a clue myself)
2 guesses for who it is :P "What do I win?" "Another post!" (no this isn' a hint) |
Well just check two of the ecu's
96DA-12A650-NB 6DNB is a police spec ecu the shift points are different and no limter on it 96DA-12A650-JA 6DJA is a EL fairmont ghia ECU got back the Speed Sen Steering still dont know what the 6DBB is yet. had these setting around and forgot what type they are:P thanks Nick
